1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: RE: Phoebus on ARM64
From: "Dudley, David via Tech-talk" <tech-talk at aps.anl.gov>
To: Heinz Junkes <junkes at fhi-berlin.mpg.de>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 26 Aug 2026 13:30:51 +0000
Although in a  larger control system I would agree, in this particular case, I'm building an independent, self-contained system to test specific hardware systems.
The control interface is entirely based and controlled by an EPICS IOC, and I'm just trying to figure on what kind of display system to use.
As FRIB uses phoebus extensively, seemed to make sense to use for the display.
This is on a BeagleBone AI-64 system, which should be more than capable of supporting phoebus, as well as an IOC that probably has less than 200 tags.
I could just as easily place a Black adjacent to the AI-64, and run the IOC on that, and the display on the other.
Again, this is an isolated, self-contained system.
Later-
David
-----Original Message-----
Sent: Wednesday, August 26, 2026 2:39 AM
To: Dudley, David <dudleyd at frib.msu.edu>
Cc: tech-talk at aps.anl.gov
Subject: Re: Phoebus on ARM64
Hi David,
we are using aarch64 (arm) Laptops, running Phoebus on it:
https://urldefense.us/v3/__https://linkprotect.cudasvc.com/url?a=https*3a*2f*2fphoebus.fhi.mpg.de*2fjob*2fphoebus-fhi-stable*2fjob*2flinux-aarch64*2f&c=E,1,iiDtUADljZo-gi1hnQopcKsVIHIg-0oIRvgBD8p0RjNdqYCm_qfMns6zzQ5e71cE1oQ-C2GJ4D6qmRaLLbEl5wKU_rlTetcLlM_m9j4oFSk,&typo=1__;JSUlJSUlJSU!!G_uCfscf7eWS!fmatHT8sxYoSRRK6metIKBORXVM-hP_G2mP2veI1TspCJkIB5Ymqk2yh6BIQVHTrklGobqqf-ip22rz48WCgToVNyg$
That should also run on the BeagleBoard.
I can agree with what Kay said. On our BeagleBone (Black) systems, only
the IOC (running under RTEMS: https://urldefense.us/v3/__https://github.com/hjunkes/RTEMS_BBB__;!!G_uCfscf7eWS!fmatHT8sxYoSRRK6metIKBORXVM-hP_G2mP2veI1TspCJkIB5Ymqk2yh6BIQVHTrklGobqqf-ip22rz48WCsePeZbg$ )
is active, and there is no display system.
I keep the two strictly separate as well.
Gruss Heinz
Fritz-Haber-Institut  | Phone: (+49 30) 8413-4270
Heinz Junkes          | VC: https://urldefense.us/v3/__https://linkprotect.cudasvc.com/url?a=https*3a*2f*2fzoom.fhi.berlin*2fjunkes&c=E,1,oGlXdkYiz8SgJEnSR7yuG1WZF_UyGzKw3x69E7mb8jUOitNilqpQBqUX7Mgf5JqDPeYMXPHxgSWU6pPtUqqL98lcL61_s2xrby5UxTODEIhT6LA4a0tyOms,&typo=1__;JSUlJQ!!G_uCfscf7eWS!fmatHT8sxYoSRRK6metIKBORXVM-hP_G2mP2veI1TspCJkIB5Ymqk2yh6BIQVHTrklGobqqf-ip22rz48WB4qOOGFA$
Faradayweg 4-6        | Visitors: Hittorfstrasse 29 (Bld S (Slough House) )
D - 14195 Berlin
“Sorry I’m a bit late, had a terrible time…
All sort of things cropping up at the last moment. Uh, how are we for time?”
—Zarquon's address to Milliways
> On 25. Aug 2026, at 17:28, Dudley, David via Tech-talk <tech-talk at aps.anl.gov> wrote:
> Has there been any thought of porting the Phoebus CSS software to ARM64?
>  I have a little BeagleBoard AI-64 system running Linux and XFCE that I’d like to get into a stand-alone test system.  I’ve got the IOC handled, all the drivers managed, and I’m down to display software.
>  Building Phoebus fails miserably.
>  Later-
>  David
Re: Phoebus on ARM64 Sukhanov, Andrei via Tech-talk
Phoebus on ARM64 Dudley, David via Tech-talk
Re: Phoebus on ARM64 Heinz Junkes via Tech-talk
Prev: Re: Phoebus on ARM64 Rea Domitrović via Tech-talk
Next: Re: Phoebus on ARM64 Sukhanov, Andrei via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: Phoebus on ARM64 Heinz Junkes via Tech-talk
ANJ, 26 Aug 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
