1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: Phoebus on ARM64
From: "Kasemir, Kay via Tech-talk" <tech-talk at aps.anl.gov>
To: "Sukhanov, Andrei" <sukhanov at bnl.gov>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 26 Aug 2026 17:42:52 +0000
> Phoebus's Data Browser appears to be limited to just a few thousand historical points.
See online help. Data Browser Live Data Sampling and Buffer Size:  https://control-system-studio.readthedocs.io/en/stable/app/databrowser/doc/index.html
Live Data Sampling
By default, traces will use a Scan Period of 0 seconds, which means we keep every sample received from the control system. To avoid running out of memory, the live data buffer has a limited Buffer Size. For example, if your channel updates every 1 second, and the buffer size is set to 5000, the data browser will keep roughly the last 1 hour and 20 minutes of live data in memory. Older samples are dropped.
To keep a longer time span of live data in memory, you can increase the Buffer Size, which obviously results in using more memory.
There’s a preference for the default buffer size:
https://control-system-studio.readthedocs.io/en/stable/preference_properties.html#package-org.csstudio.trends.databrowser3
org.csstudio.trends.databrowser3/live_buffer_size
 = 5000
Phoebus on ARM64 Dudley, David via Tech-talk
Re: Phoebus on ARM64 Kasemir, Kay via Tech-talk
RE: Phoebus on ARM64 Dudley, David via Tech-talk
Re: Phoebus on ARM64 Sukhanov, Andrei via Tech-talk
Prev: Re: Phoebus on ARM64 Sukhanov, Andrei via Tech-talk
Next: RE: Including your institute on the EPICS.org website Dudley, David via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Next: Re: Phoebus on ARM64 Heinz Junkes via Tech-talk
ANJ, 27 Aug 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
