1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: Device support for MokuPro from Liquid Instruments
From: Konrad Gajewski via Tech-talk <tech-talk at aps.anl.gov>
To: Edmund Blomley <edmund.blomley at kit.edu>
Cc: Tech Talk EPICS <tech-talk at aps.anl.gov>
Date: Fri, 11 Sep 2026 11:03:04 +0000
Hi Edmund,
I    use https://github.com/klemenv/PyDevice support module to connect devices with REST api to EPICS. It works pretty well in my case but the devices are quite simple and we have no high demand on performance (timing, bandwidth).
Cheers,
Konrad.
Skickat från min iPhone
11 sep. 2026 kl. 12:33 skrev Blomley, Edmund (IBPT) via Tech-talk <tech-talk at aps.anl.gov>:
Dear EPICS community,
A lab requested some help in getting EPICS support for a new device, which is basically a multi-purpose FPGA device.
The device is called MokuPro from Liquid Instruments[1]. It comes with a command line utility and a REST API [2]. It provides examples also for C++ [3], which seems to basically use CURL to query the Rest API. There is also a Python module [4].
While I always prefer “traditional” EPICS IOCs for hardware implementation I wonder if that is a good call if there is basically a RestAPI as the basic interface.
The next thing after a traditional EPICS IOC would be using PythonSoftIOC[5], which is Python, but still provides at least  something  close to “regular” EPICS records.
So I would be curious about what the best approach here would be. As this will probably be done by the people in the lab itself with little “traditional IOC” experience we will probably give it a first try with PythonSoftIOC.
Also, does anyone have a PythonSoftIOC implementing a RestAPI which I could take a look at?
Cheers
Eddy
[1] MokuPro: https://liquidinstruments.com/products/hardware-platforms/
[2] API Docs: https://apis.liquidinstruments.com/api/
[3] Examples in C++: https://apis.liquidinstruments.com/api/moku-examples/other-language-api/#c
[4] Moku Python module: https://pypi.org/project/moku/
[5] PythonSoftIOC: https://diamondlightsource.github.io/pythonSoftIOC/
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: Device support for MokuPro from Liquid Instruments Sukhanov, Andrei via Tech-talk
Device support for MokuPro from Liquid Instruments Blomley, Edmund (IBPT) via Tech-talk
Prev: Device support for MokuPro from Liquid Instruments Blomley, Edmund (IBPT) via Tech-talk
Next: Re: Device support for MokuPro from Liquid Instruments Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Next: Re: Device support for MokuPro from Liquid Instruments Sukhanov, Andrei via Tech-talk
ANJ, 11 Sep 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
