1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: EPICS base-3.15.9 fails to build with GCC-15
From: NICOLE Rémi via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 23 Sep 2026 09:13:36 +0000
Hello Dimitry, I had similar issues but manage to solve them with two
actions:
- Set `USR_CFLAGS="-std=c11"` in `configure/CONFIG_SITE.local`
- Apply the following commit that's on the 3.15 branch:
https://urldefense.us/v3/__https://github.com/epics-base/epics-base/commit/a509aa660d9f3ca3d2123fe16b89234065997fe6__;!!G_uCfscf7eWS!cnYQnLe4pIAGyKYVP23ScgodhnPDhZ5V_0JBalJJYIk4EKtvBXvJ2Io5UKRXjBLjjNJsYPPab7PBor53DdnK346Cow$
With this I can compile epics-base 3.15.9 with GCC 15.
Cheers!
Rémi NICOLE <remi.nicole at cea.fr>
CEA/DRF/IRFU/DIS/LDISC
On Tue, 2026-09-22 at 15:38 +0700, Dmitry Yu. Bolkhovityanov via Tech-
talk wrote:
> Hi!
> GCC-14 becomes mainstream (e.g. Debian-13), and familiar base-3.15.6
> fails to build with it.  Fotrunately, 3.15.9 was built successfully,
> but I
> wanted to check it for "future-proofness" and tried building with
> GCC-15
> and GCC-16.  It had failed with both.
> The test was carried out on Debian-13/x86_64, gcc-15.3.0 and gcc-
> 16.2.0
> built from sources and installed into /opt/.  The commandline is
>  	make CC=/opt/gcc-15/bin/gcc CCC=/opt/gcc-15/bin/g++
> and it results in error compiling src/libCom/flex/ccl.c:
> ../../../src/libCom/flex/ccl.c: In function 'list_character_set':
> ../../../src/libCom/flex/ccl.c:155:20: error: too many arguments to
> function 'readable_form'; expected 0, have 1
>    155 |             fputs( readable_form( i ), file );
> ../../../src/libCom/flex/ccl.c:143:11: note: declared here
>    143 |     char *readable_form();
> ../../../src/libCom/flex/ccl.c:162:39: error: too many arguments to
>    162 |                 fprintf( file, "-%s", readable_form( i - 1 )
> (gcc-16 produces the same result).
> Old base-7.0.7 had failed in exactly the same way, while the most
> recent
> base-7.0.10 had built successfully with both GCC-15 and GCC-16.
> (A quick inspection shows obvious fixes related to readable_form(),
> which
> was previously incorrectly declared as "readable_form()" instead of
> "readable_form(int c)".)
> The 3.15.9 is currently the latest release of EPICS3, which is still
> widely used.  And there are chances it will become unbuildable on
> modern
> systems in a year or two.
> Maybe the time for base-3.15.10 had come?
> With best regards,
> Dmitry
EPICS base-3.15.9 fails to build with GCC-15 Dmitry Yu. Bolkhovityanov via Tech-talk
Prev: RE: Error in accessing USB based DSO via E5810B Gateway GAGET Alexis via Tech-talk
Next: Same sscan record step size for all positioners not possible? J. Lewis Muir via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: EPICS base-3.15.9 fails to build with GCC-15 Dmitry Yu. Bolkhovityanov via Tech-talk
Next: Re: EPICS base-3.15.9 fails to build with GCC-15 Michael Davidsaver via Tech-talk
ANJ, 29 Sep 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
