1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: Support for 64 bit integer Normative Types?
From: Michael Davidsaver via Tech-talk <tech-talk at aps.anl.gov>
To: William Badgett <badgett at fnal.gov>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 29 Sep 2026 14:02:48 -0700
On 9/28/26 2:39 PM, William Badgett wrote:
Let me elaborate further:   The NTScalar with an int64 value field works fine in the sense of only sending out parts of the structure that have changed in value.      But when we try to int64 the event size on the Archiver Appliance PV details I see the per event size for int64 quite a lot larger than int32:
Int32 19.5 average bytes per event — DBR_SCALAR_INT DBR type
Int64  686.6 average bytes per event — DBR_V4_GENERIC_BYTES DBR type
So this was really more of an archiver appliance question — my inference is that int64 are archiving the full data structure rather than what has changed.
Correct.  The AA data model was originally defined to follow the CA protocol, which can not transport 64-bit integers.  This model has been extended to support PVA by mapping some common PVA structures to the equivalent CA types.  However, if this is not possible the fallback is to store arbitrary PVA data structures, which as you found this is less efficient.  Also, there are limitations on what queries can be made.
Supporting 64-bit scalar/array natively seems a reasonable addition.
https://github.com/archiver-appliance/epicsarchiverap/issues/550
thanks!
From: Michael Davidsaver <mdavidsaver at gmail.com>
Sent: Friday, September 25, 2026 11:53 AM
Cc: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
[EXTERNAL] – This message is from an external sender
On 9/25/26 9:19 AM, William Badgett via Tech-talk wrote:
Is there any plan to create a centrally supported signed or unsigned 64 bit integers as the value field in NTScalar ?
Like an int64outRecord?
https ://docs.epics-controls.org/projects/base/en/latest/int64outRecord.html
https ://docs.epics-controls.org/projects/base/en/latest/int64inRecord.html
Re: Support for 64 bit integer Normative Types? Sky Brewer via Tech-talk
Support for 64 bit integer Normative Types? William Badgett via Tech-talk
Re: Support for 64 bit integer Normative Types? Michael Davidsaver via Tech-talk
Re: Support for 64 bit integer Normative Types? William Badgett via Tech-talk
Prev: Re: Fanout with mask - unclear documentation on SHFT Michael Davidsaver via Tech-talk
Next: Re: EPICS base-3.15.9 fails to build with GCC-15 Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: Support for 64 bit integer Normative Types? William Badgett via Tech-talk
Next: Re: Support for 64 bit integer Normative Types? Sky Brewer via Tech-talk
ANJ, 30 Sep 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
