On 9/29/26 2:55 PM, Joel Sherrill
wrote:
It is too late to back fill this in properly
Not too late because software is never done!
but I think every project should pick a version of the
language it is using and specify that in the build system.
Not explicitly doing this leaves the language version to the
whims of whatever gcc/llvm is installed. C11 wasn't a huge
break with C99 and C17 is just a bug fix for C11. So there
wasn't a huge breakage for years of C and compiler
evolution. We were all just lucky. C23 has new features and
keywords. GCC 15 defaults to C23.
All well and good to say. We are practically bound by how these
standards are interpreted (or ignored) by the developers of
compilers. I think epics-base (and beyond) would have adopted C11
long ago if not for MSVC. And the less said about the oddities of
their "traditional" pre-processor, the better. Still, there is
hope for the future as we are able to drop support for these
older, less complaint, toolchains.
It does help to plan for this from the start. eg. with PVXS I
explicitly target c++11, at least for gcc/clang. Of course MSVC
only started allowing targeted c++ standards at c++17.
https
://github.com/epics-base/pvxs/blob/25ca43df4db909c0b1a445fb705fc81582617625/configure/toolchain.c#L14-L18
Of course when I say c++11, what I mean is c++11 as understood by
GCC 4.8, which is almost, but not quite, compliant enough for me
to ignore.
We were seeing this problem with RTEMS 5 on some
packages. The newer distributions had newer compilers which
defaulted to newer language versions. Chris Johns added
support to the RTEMS Source Builder for us to add a standard
way to specify the expected language version. This addressed
the problem packages for RTEMS.
I also am a lead on an avionics software standard that
specifies specific language versions and off-limits
features. It is not uncommon for people to not specify any
-std or specify a version not allowed in the standard and
then wonder why they don't pass conformance testing. It
isn't a bad reflection on EPICS -std isn't specified. It
unfortunately is not something that people seem to realize
is important to define as a project requirement. "EPICS
shall be written in Cnn or C++nn."
I would also add that I pushed RTEMS to be warning free
for "-Wall". Once warning free with that, we went to "-Wall
-Werror" and then "-Wall -Wextra". Before all the -Wextra
were fixed, I added -Wno-XXX to disable specific warnings.
It is thankless work but is a worthy goal.
Indeed.
https
://github.com/epics-base/epics-base/blob/e6c7dd045c2f7bb6fea43961d6a7df1328bc03f7/.github/workflows/ci-scripts-build.yml#L59-L73
https
://github.com/epics-base/pvxs/blob/25ca43df4db909c0b1a445fb705fc81582617625/.github/workflows/ci-scripts-build.yml#L50
