Subject: |
Re: [Merge] ~anj/epics-base/+git/base-3.15:decimate-filter into epics-base:3.15 |
Andrew Johnson via Core-talk <[email protected]> |
To: |
Andrew Johnson <[email protected]> |
Date: |
Mon, 08 Jul 2019 17:57:03 -0000 |
I tried adding code to set the pfl->field_size member in fl_setup(), but that wasn't enough to fix the valgrind reports and was also missing from the syncTest.c and dbndTest.c programs. I therefor added an initial memset(), which did fix them.
Last night I also committed some additional tests to those 3 programs which check for the expected number of items on the freelist, and I also fixed some leaks in the sync filter.
https://code.launchpad.net/~anj/epics-base/+git/base-3.15/+merge/368347
Your team EPICS Core Developers is subscribed to branch epics-base:3.15.
- [Merge] ~anj/epics-base/+git/base-3.15:decimate-filter into epics-base:3.15 Andrew Johnson via Core-talk
Re: [Merge] ~freddie-akeroyd/epics-base:msi_close_file into epics-base:3.15 mdavidsaver via Core-talk
Re: [Merge] ~freddie-akeroyd/epics-base:msi_close_file into epics-base:3.15 Freddie Akeroyd via Core-talk
<2019>
Re: [Merge] ~anj/epics-base/+git/base-3.15:decimate-filter into epics-base:3.15 mdavidsaver via Core-talk
Re: [Merge] ~anj/epics-base/+git/base-3.15:decimate-filter into epics-base:3.15 Andrew Johnson via Core-talk
<2019>
