On 7/17/19 4:27 PM, APS Jenkins via Core-talk wrote:
See <https://jenkins.aps.anl.gov/job/epics-base-3.15-win64-test/235/display/redirect>
macLibTest.tap ............... ok
taskwdTest.tap ...............
Failed 1/8 subtests
blockingSockTest.tap ......... ok
epicsMessageQueueTest.tap .... ok
epicsStackTraceTest.tap ...... ok
ipAddrToAsciiTest.tap ........
not ok 2 - cb.done
Failed 1/5 subtests
osiSockTest.tap .............. ok
Test Summary Report
epicsMathTest.tap (Wstat: 0 Tests: 35 Failed: 0)
TODO passed: 8-9, 11-12, 22-23
taskwdTest.tap (Wstat: 0 Tests: 7 Failed: 0)
Parse errors: Bad plan. You planned 8 tests but ran 7.
ipAddrToAsciiTest.tap (Wstat: 0 Tests: 5 Failed: 1)
Failed test: 2
Files=39, Tests=2899, 5 wallclock secs ( 0.80 usr + 0.73 sys = 1.53 CPU)
Result: FAIL
I just ran the above test programs (those same Jenkins-built binaries on the Jenkins build agent machine) by hand, both direct and through the .t wrapper. They, and the ones that failed earlier, all passed for me, so this appears to be a Jenkins wierdism.
I just reverted the other retry in the msi.plt script so this branch will build again shortly. Our Jenkins installation should be getting upgraded tomorrow morning as well, which will restart the build agents. If that doesn't fix the random failures I'll try
rebooting the Windows VM tomorrow.
- Andrew
Complexity comes for free, Simplicity you have to work for.
- Build failed in Jenkins: epics-base-3.15-win64-test #234 APS Jenkins via Core-talk
- Build failed in Jenkins: epics-base-3.15-win64-test #235 APS Jenkins via Core-talk
Build failed in Jenkins: epics-base-3.15-win64-test #236 APS Jenkins via Core-talk
<2019>
<2019>
ANJ, 17 Jul 2019 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
