2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024
Subject: Re: Misleading "initPeriodic: Scan rate ... is not achievable" and sleep quantum implementation
From: "Zimoch Dirk \(PSI\) via Core-talk" <[email protected]>
Date: Thu, 25 Jul 2019 08:23:08 +0000
On Wed, 2019-07-24 at 13:08 -0700, Michael Davidsaver via Core-talk wrote:
> On 7/24/19 1:02 PM, Johnson, Andrew N. via Core-talk wrote:
> > I don't think anyone has suggested using clock_getres() for the quantum value before; that might be a better solution than just returning zero. Anyone else want to weigh in on that idea — should we just apply Dirk's patch?
> cf. the posix version of epicsMonotonicResolution()
> I've never looked at what is returned for CLOCK_REALTIME (which is always present).
> I think the ultimate fallback has to be returning zero.  1e-3 is too arbitrary.
1e-3 is not completely arbitrary. periodicTask uses epicsEventWaitWithTimeout to
sleep which calls convertDoubleToWakeTime. The posix implementation of
convertDoubleToWakeTime uses gettimeofday if CLOCK_REALTIME is not present.
gettimeofday uses struct timeval which has only microsecond resolution.
Thus on systems where CLOCK_REALTIME does not exist, 1e-3 makes some sense.
However if there are no such posix systems, then the compiler branched can be
removed.
The posix epicsThreadSleep implementation on the other hand uses nanosleep and
is thus not limited to milliseconds.
Dirk
Misleading "initPeriodic: Scan rate ... is not achievable" and sleep quantum implementation Zimoch Dirk (PSI) via Core-talk
Re: Misleading "initPeriodic: Scan rate ... is not achievable" and sleep quantum implementation Zimoch Dirk (PSI) via Core-talk
Re: Misleading "initPeriodic: Scan rate ... is not achievable" and sleep quantum implementation Johnson, Andrew N. via Core-talk
Re: Misleading "initPeriodic: Scan rate ... is not achievable" and sleep quantum implementation Michael Davidsaver via Core-talk
Prev: Jenkins build is still unstable: epics-7.0 » mac #137 APS Jenkins via Core-talk
Next: Build failed: epics-base base-7.0-277 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024
Prev: Re: Misleading "initPeriodic: Scan rate ... is not achievable" and sleep quantum implementation Michael Davidsaver via Core-talk
Next: EPICS 7 array link inconsistencies Zimoch Dirk (PSI) via Core-talk
ANJ, 25 Jul 2019 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
