Subject: |
[Bug 541239] Re: explicitly unloading Com.dll causes crash |
Andrew Johnson via Core-talk <[email protected]> |
To: |
[email protected] |
Date: |
Tue, 15 Oct 2019 15:46:18 -0000 |
If there are any epicsThreads (such as the errlog thread) that have not
been shut down before you unload the library they will probably cause a
crash. We don't currently have a 'stop all threads' API that could be
called to shut everything down without exiting, but it's something that
could be provided for the libCom and CA subsystems at least, and recent
changes on the EPICS 7 branch might make this easier.
Comment here or email the EPICS core-talk list with any offers of help
to develop this...
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/541239
Title:
Status in EPICS Base:
Fix Released
Bug description:
From Liyu Andrei:
I met problem with CA again. If I did the simplest program in
Visual C++
iStatus = ca_context_create( ca_enable_preemptive_callback);
ca_context_destroy();
I don't see any message.
If I do dll with function that has empty body and call it from
LabView I haven't problem too. Couple sentence about it if you haven't
experience with LabView. At first, there LabView has next steps
- start LabView
- loads VI (LabView program)
- VI starts - stops
- unload VI
- stop LabView
Then If I add these couple lines in function body
- LabView program (VI) continues to work. I can run a lot of times.
- if I close (unload) LabView program (VI) LabView craches with next
message
Unhandled exception in LabView.exe:0xC0000005:Access Violation
I see this message because I work under Visual C++. I don't see anything
in normal usage (without VC).
Now I work with Epics 3.14.4.
Maybe you have any suggestion?
Additional information:
A program reproducing this issue....
// linkTest.cpp : Defines the entry point for the console application.
#include "stdio.h"
#include "windows.h"
#include "cadef.h"
typedef int ( epicsShareAPI * p_ca_context_create)
( enum ca_preemptive_callback_select );
typedef void ( epicsShareAPI * p_ca_context_destroy )
( void );
typedef int ( epicsShareAPI * p_ca_create_channel )
const char *pChanName,
caCh *pConnStateCallback,
void *pUserPrivate,
capri priority,
chid *pChanID
typedef int ( epicsShareAPI * p_ca_clear_channel )
chid
typedef int ( epicsShareAPI * p_ca_pend_io )
( ca_real timeOut );
void MYSEVCHK (int CA_ERROR_CODE, const char * MESSAGE_STRING)
if(!(CA_ERROR_CODE & CA_M_SUCCESS)) {
fprintf ( stderr, "exiting because CA status was %d context was "%s"\n",
CA_ERROR_CODE,
MESSAGE_STRING );
SuspendThread ( GetCurrentThread () );
#define myassert(EXP) ((EXP)?(void)1:_myassert(#EXP))
void _myassert ( const char * pStr )
fprintf ( stderr,
"assert fail "%s"\n", pStr ),
int main ( int argc, char ** argv[] )
for ( unsigned i = 0; i < 1000; i++ ) {
HINSTANCE hLibrary = LoadLibrary("ca");
myassert ( hLibrary );
p_ca_context_create pF_ca_context_create = ( p_ca_context_create )
GetProcAddress( hLibrary, "_ca_context_create@4" );
myassert ( pF_ca_context_create );
p_ca_context_destroy pF_ca_context_destroy = ( p_ca_context_destroy )
GetProcAddress( hLibrary, "_ca_context_destroy@0" );
myassert ( pF_ca_context_destroy );
p_ca_create_channel pF_ca_create_channel = ( p_ca_create_channel )
GetProcAddress( hLibrary, "_ca_create_channel@20" );
myassert ( pF_ca_create_channel );
p_ca_clear_channel pF_ca_clear_channel = ( p_ca_clear_channel )
GetProcAddress( hLibrary, "_ca_clear_channel@4" );
myassert ( pF_ca_clear_channel );
p_ca_pend_io pF_ca_pend_io = ( p_ca_pend_io )
GetProcAddress( hLibrary, "_ca_pend_io@8" );
myassert ( pF_ca_pend_io );
int status = ( *pF_ca_context_create )
( ca_disable_preemptive_callback );
MYSEVCHK ( status, "context create failed" );
chid chan;
status = ( *pF_ca_create_channel )
( "DTL_Diag:ND130:FaWave", 0, 0, 0, &chan );
MYSEVCHK ( status, "create channel failed" );
status = ( *pF_ca_pend_io ) ( 10.0 );
MYSEVCHK ( status, "channel connect failed" );
status = ( *pF_ca_clear_channel ) ( chan );
MYSEVCHK ( status, "channel clear failed" );
( *pF_ca_context_destroy ) ();
FreeLibrary( hLibrary);
return 0;
Original Mantis Bug: mantis-195
http://www.aps.anl.gov/epics/mantis/view_bug_page.php?f_id=195
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/541239/+subscriptions
[Bug 541330] Re: 'assert (size <= ntohs ( pMsg->m_postsize ))' failed in ..caserverio.c line 344 Andrew Johnson via Core-talk
[Bug 1815908] Re: casExpandRecvBuffer modifies the contents of the buffer mdavidsaver via Core-talk
<2019>
[Merge] ~anj/epics-base/+git/base-3.15:epics-prove into epics-base:3.15 Andrew Johnson via Core-talk
<2019>
