Subject: |
[Merge] ~info-martin-konrad/epics-base:remove-epicsthrows into epics-base:7.0 |
Martin Konrad via Core-talk <[email protected]> |
To: |
[email protected] |
Date: |
Tue, 12 Nov 2019 17:19:21 -0000 |
Martin Konrad has proposed merging ~info-martin-konrad/epics-base:remove-epicsthrows into epics-base:7.0.
Requested reviews:
EPICS Core Developers (epics-core)
For more details, see:
https://code.launchpad.net/~info-martin-konrad/epics-base/+git/epics-base/+merge/375445
Potential impact on users, let's merge this into 7.0.
Your team EPICS Core Developers is requested to review the proposed merge of ~info-martin-konrad/epics-base:remove-epicsthrows into epics-base:7.0.
diff --git a/modules/libcom/src/osi/compiler/clang/compilerSpecific.h b/modules/libcom/src/osi/compiler/clang/compilerSpecific.h
index 2053227..0498f6e 100644
--- a/modules/libcom/src/osi/compiler/clang/compilerSpecific.h
+++ b/modules/libcom/src/osi/compiler/clang/compilerSpecific.h
@@ -33,10 +33,8 @@
* CXX_PLACEMENT_DELETE - defined if compiler supports placement delete
- * CXX_THROW_SPECIFICATION - defined if compiler supports throw specification
#define CXX_PLACEMENT_DELETE
-#define CXX_THROW_SPECIFICATION
#endif /* __cplusplus */
diff --git a/modules/libcom/src/osi/compiler/gcc/compilerSpecific.h b/modules/libcom/src/osi/compiler/gcc/compilerSpecific.h
index 13d9119..f053495 100644
--- a/modules/libcom/src/osi/compiler/gcc/compilerSpecific.h
+++ b/modules/libcom/src/osi/compiler/gcc/compilerSpecific.h
@@ -44,13 +44,8 @@
-#if __GNUC__ > 2 || ( __GNUC__ == 2 && __GNUC_MINOR__ >= 95 )
-# define CXX_THROW_SPECIFICATION
-#endif
#if __GNUC__ > 2 || ( __GNUC__ == 2 && __GNUC_MINOR__ >= 96 )
# define CXX_PLACEMENT_DELETE
#endif
diff --git a/modules/libcom/src/osi/compilerDependencies.h b/modules/libcom/src/osi/compilerDependencies.h
index 3bd835c..0b333d7 100644
--- a/modules/libcom/src/osi/compilerDependencies.h
+++ b/modules/libcom/src/osi/compilerDependencies.h
@@ -21,18 +21,6 @@
#ifdef __cplusplus
- * usage: void func () epicsThrows (( std::bad_alloc, std::logic_error ))
- * Note: now a widely accepted concensus (ref Meyers and C++ faq) is that
- * one should avoid using throw specifications in C++ code
-#if defined ( CXX_THROW_SPECIFICATION )
-# define epicsThrows(X) throw X
-#else
-#endif
* usage: epicsPlacementDeleteOperator (( void *, myMemoryManager & ))
#if defined ( CXX_PLACEMENT_DELETE )
- Re: [Merge] ~info-martin-konrad/epics-base:remove-epicsthrows into epics-base:7.0 mdavidsaver via Core-talk
- [Merge] ~info-martin-konrad/epics-base:remove-epicsthrows into epics-base:7.0 mdavidsaver via Core-talk
New day/time for teleconference? Konrad, Martin via Core-talk
[Merge] ~info-martin-konrad/epics-base:retire-epicsexcept into epics-base:3.15 Martin Konrad via Core-talk
<2019>
Re: New day/time for teleconference? Ralph Lange via Core-talk
<2019>
