I've downloaded the last 3.14.7 Release from the EPICS-Site and tried to build it for solaris-sparc. (Solaris 8.0) The build crashed with the following error: /opt/SUNWspro/bin/cc -c -D_POSIX_C_SOURCE=199506L -D_XOPEN_SOURCE=500 -DUNIX -DSOLARIS=8 -mt -D__EXTENSIONS__ -Xc -v -xO4 -DEPICS_COMMANDLINE_LIBRARY=EPICS_COMMANDLINE_LIBRARY_READLINE -KPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/solaris -I../../../include -I/opt/gnu/include ../../../src/libCom/osi/os/default/epicsReadline.c "../../../src/libCom/osi/os/default/epicsReadline.c", line 76: cannot find include file: <readline/readline.h> "../../../src/libCom/osi/os/default/epicsReadline.c", line 77: cannot find include file: <readline/history.h> "../../../src/libCom/osi/os/default/epicsReadline.c", line 101: warning: implicit function declaration: stifle_history "../../../src/libCom/osi/os/default/epicsReadline.c", line 102: warning: implicit function declaration: rl_bind_key "../../../src/libCom/osi/os/default/epicsReadline.c", line 102: undefined symbol: rl_insert "../../../src/libCom/osi/os/default/epicsReadline.c", line 124: warning: implicit function declaration: readline "../../../src/libCom/osi/os/default/epicsReadline.c", line 124: warning: improper pointer/integer combination: op "=" "../../../src/libCom/osi/os/default/epicsReadline.c", line 162: warning: implicit function declaration: add_history cc: acomp failed for ../../../src/libCom/osi/os/default/epicsReadline.c gmake[3]: *** [epicsReadline.o] Error 2 My workaround for this error, in the base/src/libCom/osi/os/default/epicsReadLine.c file: -- delete this line --- #ifndef EPICS_COMMANDLINE_LIBRARY #define EPICS_COMMANDLINE_LIBRARY EPICS_COMMANDLINE_LIBRARY_EPICS -- delete this line --- #endif OR -- add this line outside of that define --- #define EPICS_COMMANDLINE_LIBRARY EPICS_COMMANDLINE_LIBRARY_EPICS Both represents the same ;-). This is one solution for me for now, but please let me know, if there is a more official one ? Release 3.14.6 can be built without such an error. Regards, Zoltan -- Zoltan Kakucs, M.Sc. Deutsches Elektronen-Synchrotron DESY in der Helmholtz-Gemeinschaft Cryogenic Control Group Notkestraße 85 D-22607 Hamburg +49 (0) 40 8998 - 3283 Voice +49 (0) 40 8998 - 4388 Fax mailto: [email protected] DESY Hamburg at http://www.desy.de *********************************************************** "Mut bedeutet nicht, keine Angst zu haben, sondern es ist die Entscheidung, dass etwas anderes wichtiger ist, als die Angst." Ambrose Red Moon ***********************************************************
ANJ, 02 Sep 2010 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
