On Nov 16, 2005, at 14:31 , Emmanuel Mayssat wrote: I am actually doing something quite similar, but I am using a standard Well, define "epics can only process .. at a maximum rate of 10Hz". Yes, per default, the EPICS record scan rates (periods) include "10 second, 5 second, .... 0.1 second", which gives a max. of 10Hz. But under vxWorks, especially after increasing the vxWorks 'tick' clock rate, one can usually simply change the menuScan.dbd file and add e.g. ".05 second" and voila: "epics can ... process .. at a maximum rate of 20Hz". But what you probably really want is: Process in response to whatever triggers your camera to take a picture. Just like ADC driver/device support can be written to process records on "I/O Intr" whenever the ADC receives a trigger, you can write your frame grabber support to trigger record processing whenever the frame grabber gets a new image. The IOC application developer guide has details on the "I/O Intr" mechanism. The EPICS "Event" mechanism might also work. For example, the SNS LLRF driver/device support can trigger certain records to process on each RF pulse, which could be up to 60 Hz. So "epics can ... process .. at a maximum rate of 60Hz". I think there are examples out there in the EPICS community of much higher rates. The next problem: When records process at a high rate _and_ there are channel access clients which subscribed to updates from those records, every time the records process, data is sent to those clients (ignoring some ADEL/MDEL details). In the case of the SNS LLRF, those records include waveforms. All is OK as long as only one set of EDM screens is displaying those waveforms. In practice, however, many screens are open. Even though nobody is necessarily looking at the waveforms in all of them, they all receive data from the IOC, because the current Channel Access network protocol doesn't allow client-specific update rates. That's putting too much load on the IOC and network, and thus the overall update rate suffers. So the waveform update rate of the SNS LLRF was throttled to 2Hz, using a 2Hz signal from the timing system, so gets updates from all of the linac at exactly the same time, which appeared to be more useful than more or less random update rates. So one could say "with many waveforms served by MVME2100 CPUs, monitored by many network clients, epics can ... publish data .. at a maximum rate of 2Hz". I would assume that even if you only have an MVME2100 CPU, you should be able to serve 640x400-sized images at 30Hz to one or two network clients. -Kay
ANJ, 02 Sep 2010 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
