Hi All, Following are the two cases for which Striptool is getting crashed. 1) Striptool version 2.5.10.0 with Epics Base version 3.14.11. On the striptool graph window, right click and select toggle buttons option. If you do it one or more times, the strip toll is getting crashed. Following is the crash message. /.../linux-x86_64/engMenu_startStripTool: line 76: 13044 Segmentation fault StripTool ${configurationDir}/${fileName} 2) Striptool version 2.5.12.0 with Epics Base version 3.14.11. On the striptool graph window, right click and select control option and immediately the striptool crashes. Following are the log messages. ==== StripTool Xt Warning Handler ==== warning: Axis: minVal is greater than or equal to maxVal ==== StripTool Xt Warning Handler ==== warning: Axis: minVal is greater than or equal to maxVal Segmentation fault If there are any solutions for the above problems, please let me know. Best Regards, Ramu
ANJ, 02 Sep 2010 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
