Sometime I see in the CA gateway log file entries like this: filename="../../../../src/cas/generic/casPVI.cc" line number=251 Bad data type application type "enums" string conversion table for enumerated PV isnt a string type? Can anyone tell me what this means? Unfortunately it does not print any context like PV name or involved enum strings. So the problem is quite hard to debug. The message comes from void casPVI::updateEnumStringTableAsyncCompletion(const gdd & resp) I suspect this may happen when the enum string set has been modified on the IOC while the channel is connected though the gateway. Dirk
ANJ, 16 Sep 2010 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
