Right now I plan to keep an Arduino (possibly a Mega) and a Pi in a cabinet that will house the power supply, relays, etc. The Pi would be networked, and a laptop or tablet would be the control panel. So lack of medm for ARM isn't all that concerning. For low level IO, I think I need an Arduino. Flow rate sensors use Hall effect chips to generate pulses. With an Arduino I can attach the pins to interrupts. With a Pi or BeagleBone Black, I'd need to poll the pins in a tight loop looking for changes and could miss pulses, yes? Also have you seen the Raspberry Pi Compute Module? Lots of GPIO, multiple UARTS, etc. I don't think it's needed for this project. Also, I might be overreacting, but I figure keeping the low level control on an Arduino provides some insulation against Linux system crashes. In the case of failure, things will tend to stay in the same state. Thanks, Ryan -------- Original message -------- From: Emmanuel Mayssat Date:08/11/2014 7:51 PM (GMT-06:00) To: EPICS mailing list Subject: RE: New to EPICS - system design questions 1/ medm doesn't compile on ARM, IOS, android... good luck with CSS! only epicsqt supports all those platforms
2/ if you use an arduino, you can use the USB port to communicate with the host 3/ for usb or serial (if you buy the serial shield) or ethernet (need shield) you can use streamdevice 4/ keep you program simple on the arduino side otherwise you have to watch for memory leak (on the arduino heap) 5/ raspberry pi is great, beaglebone black may be better and cheaper overall (you won't need an arduino or a gpio plate (shield) for your pi) 6/ you don't need epics if you just want to publish data on the web Let me know if you need help. -- E > Subject: New to EPICS - system design questions > From: [email protected] > Date: Mon, 11 Aug 2014 13:22:34 -0500 > To: [email protected] > > I'm new to EPICS and am interested in putting it to some possibly unique uses. I'm a member of the Pumping Station: One makerspace in Chicago, which is a large non-profit community workshop with all sorts of tools (wood shop, machine shop, welding, electronics lab, CNC fabrication equipment, etc. and a scanning electron microscope, which I coordinate maintenance and training for) where members can collaborate and work on projects. > > I'd like to use EPICS to control a custom all-grain beer brewing system I am constructing. I'm considering using an Arduino variant to do all low level hardware control, e.g. commanding valves, pumps, propane burners and/or heater elements, reading temperature, pressure, and flow sensors, etc. I'm guessing this would communicate via serial to a Raspberry Pi, which would run an EPICS IOC. I would use a laptop (or tablet?) networked via WiFi to the Pi as the control panel. > > I know this sounds kind of strange, but the more I think about it, the more I like the idea of not having to write networking code or GUI for a control panel. Everything about the brewing system abstracts logically to process variables. I'm starting through the archived video presentations on a EPICS, and I'm wondering what best practices are for some of these things which I'm sure would also be used for more traditional science applications. > > PID control: Code it on the Arduino, and expose the set point, PID constants and state over serial to the Pi, which exposes these as process variables? Or have the Arduino just expose the raw sensor data to the Pi, which exposes them as process variables, and run a separate process on the Pi that is an IOC publishing set point, PID constants, etc. that in turn reads and commands the lower level process variables? Or does EPICS have constructs for this already? > > Ramp / Soak: this will drive the PID set point. I'd need to program profiles in with multiple temperatures and times. A process on the Pi maybe? > > Event sequencing: I see EPICS has support for this. I'm not sure where to implement functions like "Add X quarts of water to the tank" where it would need to open a solenoid valve, count pulses on a flow meter, and close it when the level is reached. Or higher level sequences, like "first, fill the tank with X quarts, then heat it to this temperature and hold it there via PID, then prompt the user to dump in the grain, then run this ramp/soak profile", etc. > > Alarms: I need the concept of multiple alarms that can be acknowledged / overridden. (Time to add grain, time to add hops, the pump flow rate dropped too low, etc.) I'm guessing this is a common problem and am wondering if there are already common solutions for this. > > I'm interested in "async"; I'm wondering if this would make things easier by handling serial communications with the Arduino and allowing me to publish PVs on the Arduino without writing custom IOC code on the Pi. > > Is MEDM still the way to go for control panels? I'm also wondering if there are any EPICS compatible control panel apps for IPad or Android tablets. > > I'd like to publish data to the web so interested people can see the state of the brewing. Is there any kind of framework for publishing EPICS PVs to the web without having to write lots of custom code? > > Anyway, I know this is unusual, but it sounded like a fun project to me. I think it would be interesting to see what would happen if EPICS and the maker community intersected. > > Thanks, > Ryan
ANJ, 17 Dec 2015 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
