Hello EPICS users.
We are trying to run an IOC on Windows x64 using mingw, and we encountered some problems, as the title states. First of all, we are having a problem with the IOC .dbd file, the IOC initializes but from what we understood, st.cmd is not running, when we are trying to run just this file, it gives us the error:
# is not a recognized command. Perl is installed and in Path, Mingw is installed and in Path. We can enter epics shell, the commands work, we can open the .dbd and .db device in VDCT.
But when we use "dbl" it says:"No database loaded". We were able to run MEDM as well, and here comes the second problem, how can we install the fonts required by MEDM? On the EPICS webpage, the link towards downloads it's just a .txt file, we tried to use save link as but it did not work.
----------------------------------------------------------------------------- Kind RegardsRusu Vlad Andrei & Bertrand de Boisdeffre
ANJ, 17 Dec 2015 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
