Hi all,
Question is: How can I changed the timeout for drvAsynSerialPort? Context follows (maybe I'm asking the wrong question): I've been working through a tutorial* with few modifications. So far no problems until I try to initiate communication with a Stanford Research Systems PS365 HV supply. When I run ./st.cmd, everything says it initializes, but then I get a message saying that the ioc did not receive a response within 1 second. The exact error(s) are: 2014/12/10 17:31:18.937952 L0 ps365controlTestIDN: No reply from device within 1000 ms 2014/12/10 17:31:20.039439 L0 ps365controlTestIDNwf: No reply from device within 1000 ms Further, if I query the ioc with "caget -S ps365controlTestIDNwf", I get this: ps365controlTestIDNwf \003 CA.Client.Exception............................................... Warning: "Identical process variable names on multiple servers" Context: "Channel: "ps365controlTestIDNwf", Connecting to: 198.128.196.226:5064, Ignored: franklins-mbp.dhcp.lbl.gov:5064" Source File: ../cac.cpp line 1298 Current Time: Wed Dec 10 2014 17:44:31.920218000 I can "manually" communicate with the device using a simple screen command. I use the same port address with 9660/8/N/1 standard settings. It seems to take a second, maybe 2, to open the connection. So my thought was that maybe I just need to have the asyn driver increase its timeout time to avoid this error. I can't see a way to change the timeout, however. * The tutorial in question: http://www.aps.anl.gov/epics/modules/soft/asyn/R4-21/HowToDoSerial/HowToDoSerial_StreamDevice.html My st.cmd is given below: #!../../bin/darwin-x86/ps365controlTest ########################################## # Setup Environment < envPaths epicsEnvSet "STREAM_PROTOCOL_PATH" "$(TOP)/db" ########################################## # Allow PV prefixes and serial port name to be set from the environment epicsEnvSet "P" "$(P=ps365control)" epicsEnvSet "R" "$(R=Test)" epicsEnvSet "TTY" "$(TTY=/dev/ttyUSB)" ########################################## # Register all support components cd ${TOP} dbLoadDatabase(dbd/ps365controlTest.dbd) ps365controlTest_registerRecordDeviceDriver(pdbbase) ########################################## # Set up ASYN ports drvAsynSerialPortConfigure("L0","$(TTY)",0,0,0) #sets up a port L0 at $TTY (see above) #now we fill in the details of the port connection #9600/8/N/1 is the most typical serial port configuration asynSetOption("L0",-1,"baud","9600" asynSetOption("L0",-1,"bits","8") asynSetOption("L0",-1,"parity","none") asynSetOption("L0",-1,"stop","1") asynSetOption("L0",-1,"clocal","Y") asynSetOption("L0",-1,"crtscts","N") ########################################## ## Load record instances dbLoadRecords("db/devps365control.db","P=$(P),R=$(R),PORT=L0,A=0") ########################################## # Start EPICS cd ${TOP}/iocBoot/${IOC}
ANJ, 17 Dec 2015 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
