Hi Andrew,
The error message appears to be coming from StreamDevice AsynDriverInterface.c::lockRequest:
// interface function: we want exclusive access to the device
// lockTimeout_ms=0 means "block here" (used in @init)
bool AsynDriverInterface::
lockRequest(unsigned long lockTimeout_ms)
int connected;
asynStatus status;
debug("AsynDriverInterface::lockRequest(%s, %ld msec)\n",
clientName(), lockTimeout_ms);
lockTimeout = lockTimeout_ms ? lockTimeout_ms*0.001 : -1.0;
ioAction = Lock;
status = pasynManager->isConnected(pasynUser, &connected);
if (status != asynSuccess)
error("%s: pasynManager->isConnected() failed: %s\n",
clientName(), pasynUser->errorMessage);
return false;
status = pasynManager->queueRequest(pasynUser,
connected ? priority() : asynQueuePriorityConnect,
lockTimeout);
error("%s lockRequest: pasynManager->queueRequest() failed: %s\n",
return false;
// continues with:
// handleRequest() -> lockHandler() -> lockCallback()
// or handleTimeout() -> lockCallback(StreamIoTimeout)
return true;
This part of the error message:
asynManager::queueRequest is already queued
comes from asynManager. It says that a second call to pasynManager->queueRequest has been made with the same pasynUser structure as an existing queueRequest that has not yet completed.
How are you arranging to poll the device every 4 seconds?
This may be a case where your should write your own asyn driver rather than using StreamDevice. You could then handle the complex parsing of the combined responses in your C++ code.
You could write your driver using asynPortDriver, and call pasynOctetSyncIO->writeRead for the command/response commands and pasynOctetSyncIO->read for the unsolicited messages.
Hi Everyone,
I have a particularly tricky serial device I am working on programming. To make matters worse it has a very slow response speed to commands.
It sends unsolicited commands, but also does normal request response messages. I am usually polling the device every 4 seconds while it is running. Very often when receiving the unsolicited commands I receive the following error:
2014/12/30 20:14:13.939 timerQueue XR:Message lockRequest: pasynManager->queueRequest() failed: asynManager::queueRequest is already queued
I tried searching techtalk but cannot seem to find anyone with a similar issue. This is very problematic because this device is very slow and the unsolicited messages are the most important. Also I should mention that all commands I receive
from the device need to be acknowledged, so immediately after the "in" string in the protocol follow I have an out string with the same format.
(Another problem I have is that if the device has messages to send very close together in timing it will group them into a single message but with an unpredictable order. I have no idea how to deal with this. I can imagine a cascading mismatch
sequence but this would be very complex. Is regex the only other option? When it does group the messages they are delimited by a space, but in all other instances it is just single messages with no space. I almost need some sort of function to search for a
space and if it finds it to separate the messages, but otherwise ignore the normal messages).
I'm using stream device 2-6 and asyn4-21. Unfortunately can't post the db or protocol file because I had to sign a NDA for this device.
