1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024
Subject: Re: firewalld configuration for EPICS?
To: Dirk Zimoch <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 3 May 2019 16:53:56 +0000
Dirk’s method shown below works for multiple SoftIOCs on a Linux host, the CA server side.
I guess “EPICS.xml” mentioned by Jörn is also for the firewall configuration on the CA server side.
For the CA client side, has anyone done the firewall configuration on a Linux workstation running CA clients (EDM, CS-Studio, camonitor, etc.)? As Benjamin pointed out below, I guess it is difficult to configure the firewall for CA clients because of the dynamically assigned TCP port (CA server side) when multiple SoftIOCs running on a Linux host.
Firewall is mentioned in the CA Reference Manual [1] for the classic EPICS v3. I think the rules (only INPUT chain is concerned) in the Manual only work for the case where a single IOC runs on Linux. After looking through the CA Protocol Specification, my observation is that the rules are not complete for a CA client while the rules for a CA server are complete. Another rule is needed “-A INPUT -s 192.168.0.0/22 -p tcp --sport 5064 -j ACCEPT” for a CA client so that the complete rules look like below. Is my observation valid?
# rules for the CA client side:
     -A INPUT -s 192.168.0.0/22 -p udp --sport 5064 -j ACCEPT        #allow CA client to get PV search replies
     -A INPUT -s 192.168.0.0/22 -p udp --dport 5065 -j ACCEPT       #allow CA client to see beacons
     -A INPUT -s 192.168.0.0/22 -p tcp   --sport 5064 -j ACCEPT       #allow CA client to get data from CA server over TCP
# rules for the CA server side:
     -A INPUT -s 192.168.0.0/22 -p udp --dport 5064 -j ACCEPT       #allow CA server to see PV search request
     -A INPUT -s 192.168.0.0/22 -p tcp  --dport 5064 -j ACCEPT       #allow CA server to get data from CA client over TCP
Best,
Yong
NSLS-II Controls Group
[1] https://epics.anl.gov/base/R3-15/6-docs/CAref.html#firewall
[2] https://epics.anl.gov/base/R3-15/6-docs/CAproto/index.html
From: <[email protected]> on behalf of "[email protected]" <[email protected]>
Reply-To: Dirk Zimoch <[email protected]>
Date: Wednesday, April 10, 2019 at 5:01 AM
I could open all ephemeral ports, but that's a lot. And it's not what
local firewalls typically do.
But I found a way to dynamically open and close used TCP server ports.
I wrote this script "open_firewall.sh":
#!/bin/bash
SERVERPID=$PPID
TCPPORTS=$(netstat -tlpn | awk -F '[ :]+' "/ $SERVERPID\//"'{print $5}')
for port in $TCPPORTS
   do firewall-cmd -q --add-port=$port/tcp
done
   close_ports () {
       do firewall-cmd -q --remove-port=$port/tcp
     done
   trap close_ports EXIT
   while [ -d /proc/$SERVERPID ]
     do sleep 10
   done
In the IOC after iocInit I call: system open_firewall.sh
This opens all TCP ports in the firewall where the IOC installed a
server, including CA and PVA server ports.
When the IOC exits, the ports are closed automatically, even when the
IOC crashes or gets killed with -9.
Example starting a second EPICS 7 IOC:
Starting iocInit
## EPICS R7.0.1.2-DEV-2018-10
## EPICS Base built Oct 31 2018
cas warning: Configured TCP port was unavailable.
cas warning: Using dynamically assigned TCP port 39673,
cas warning: but now two or more servers share the same UDP port.
cas warning: Depending on your IP kernel this server may not be
cas warning: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST)
2019-04-10T11:51:51.582 Using dynamically assigned TCP port 52773.
epics> system "firewall-cmd --list-ports"
5064/tcp 5075/tcp 52773/tcp 39673/tcp
epics> exit
Terminated
# firewall-cmd --list-ports
5064/tcp 5075/tcp
The script should work with any (Linux) server, not only EPICS IOCs,
which opens all server ports at startup. It simply uses the parent
process id to look for open ports. Of course bash, netstat, awk and
firewall-cmd must be installed and /proc must be mounted.
Dirk
On 09.04.19 19:03, Benjamin Franksen via Tech-talk wrote:
Am 09.04.19 um 17:18 schrieb Dirk Zimoch via Tech-talk:
I had not thought of the multiple IOC problem. In this case it is a
Fedora Linux VME IOC. Unlikely to run multiple IOCs but not impossible.
I tried it and naively accessing records on IOC 2 does not work when the
firewall is up. I get  'CAC: Unable to connect because "No route to
host"' on the client (caget) even when using the broadcast address.
Ah, I didn't understand that you were talking about firewall on the
machine that runs the IOC(s). My remark was about firewall on the CA client.
Anyway, I thought that services such as a web server use dynamically
assigned (ephemeral) ports for the actual data exchange and the
well-known port only to initiate communication. I guess a firewall can
be configured to allow connections to a web server, so shouldn't it be
possible to do the same for (multiple) IOCs?
Cheers
Ben
Re: firewalld configuration for EPICS? Zimoch Dirk (PSI) via Tech-talk
firewalld configuration for EPICS? Dirk Zimoch via Tech-talk
Re: firewalld configuration for EPICS? Jörn Dreyer via Tech-talk
Re: firewalld configuration for EPICS? Dirk Zimoch via Tech-talk
Re: firewalld configuration for EPICS? Benjamin Franksen via Tech-talk
Prev: Re: Pmac Slits giles.knap--- via Tech-talk
Next: Re: RES: Pmac Slits Davis, Mark via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024
Prev: Re: firewalld configuration for EPICS? Dirk Zimoch via Tech-talk
Next: Re: firewalld configuration for EPICS? Zimoch Dirk (PSI) via Tech-talk
ANJ, 04 May 2019 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
