1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024
Subject: Re: Record not processing in simulation mode
From: Ralph Lange via Tech-talk <[email protected]>
To: "Konrad, Martin" <[email protected]>
Date: Mon, 13 May 2019 21:02:43 +0200
On Mon, 13 May 2019 at 20:01, Konrad, Martin via Tech-talk <[email protected]> wrote:
Using simulation mode for the first time I noticed some behavior I
didn't expect.
However, when I try the same thing with a record that is tied to
hardware (also RTYP=ai but DTYP=asynFloat64, SCAN=I/O Intr) the record
doesn't process on writes to the SVAL field. Poking it manually ("caput
foo.PROC 1") triggers processing, though.
Is this how it should be? If so can someone shine some light on why it
is behaving like this?
This is how simulation mode was broken from the very beginning until recently (EPICS 7). ;-)
As 'I/O Intr' scanned records get scanned when the Device Support triggers them, and simulation mode - by definition - means that there is no Device Support, you have to configure the field SSCN (Simulation Scan) to have 'I/O Intr' records scanned using another mechanism in simulation mode.
See also 'Simulation Mode Improvements' in the Release Notes (will also be in the App Developers for EPICS 7).
Cheers,
~Ralph
Record not processing in simulation mode Konrad, Martin via Tech-talk
Prev: Re: Record not processing in simulation mode Konrad, Martin via Tech-talk
Next: Re: Using PVUtil to get PV's value when PV name is input as string in CSS Davide Marcato via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024
Next: Re: Record not processing in simulation mode Konrad, Martin via Tech-talk
ANJ, 14 May 2019 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
