1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024
Subject: Re: No TCP server started
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Mon, 4 Nov 2019 09:20:36 +0100
Do you use the same settings for the EPICS_CA_* variables when you're running the IOC successfully from a terminal?
Cheers,
~Ralph
Re: No TCP server started Pierrick M Hanlet via Tech-talk
Re: No TCP server started Michael Davidsaver via Tech-talk
Re: No TCP server started Mark Rivers via Tech-talk
RE: No TCP server started Mark Rivers via Tech-talk
Prev: build stream =?gb18030?b?t+fQ0Muu?= via Tech-talk
Next: execute python from st.cmd Sandeep Kumar Malu - UKRI STFC via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024
Prev: RE: No TCP server started Mark Rivers via Tech-talk
Next: Re: No TCP server started Pierrick M Hanlet via Tech-talk
ANJ, 04 Nov 2019 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
