Hi Jeong Han,
Sounds good.
The memDisplay module added and solved compile errors.
One more error is coming from the "regdev/test" file.
fpga@debian10-zcu102:~/iocApp/regdev/test$ make
gcc -g -c test_regDevWriteNumber.c -Wall -Werror \
-I. -I .. -I/home/fpga/epics/base-3.16.2/include -I/home/fpga/epics/base-3.16.2/include/os/Linux
In file included from /home/fpga/epics/base-3.16.2/include/epicsTypes.h:19,
from test_regDevWriteNumber.c:4:
/home/fpga/epics/base-3.16.2/include/compilerDependencies.h:19:10: fatal error: compilerSpecific.h: No existe el fichero o el directorio
#include "compilerSpecific.h"
compilation terminated.
make: *** [Makefile:16: test_regDevWriteNumber.o] Error 1
Kiman
-----Original Message-----
Sent: Friday, November 08, 2019 5:46 PM
To: Ha, Kiman <[email protected]>; [email protected]; Zimoch Dirk (PSI) <[email protected]>
Cc: [email protected]
Subject: Re: Xilinx ARM64 mmap and regdev module compile error
Hi Kiman,
You need memDisplay[1] in order to compile regdev[3] correctly.
And there may be one more dependent module, symbolname [2]. Please look at
https://github.com/paulscherrerinstitute/memDisplay/blob/master/configure/RELEASE#L22
However, symbolname doesn't have the standard EPICS building system.
HTH
Han
[1] https://github.com/paulscherrerinstitute/memDisplay
[2] https://github.com/paulscherrerinstitute/symbolname
[3] https://github.com/paulscherrerinstitute/regdev
On 11/8/19 7:52 PM, Ha, Kiman via Tech-talk wrote:
> Hi Dirk,
> I am trying to build a mmap & regdrv device support module for ARM64
> Debian10 and got some errors.
> It seems environment issue and needs additional modules?
> fpga@debian10-zcu102:~/iocApp/mmap$ make
> GNUmakefile:2: It seems you do not have the PSI build environment.
> Remove GNUmakefile.
> make -C O.linux-arm -f ../Makefile TOP=./.. \
> T_A=linux-arm install
> make[1]: se entra en el directorio '/home/fpga/iocApp/mmap/O.linux-arm'
> /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUNIX
> -Dlinux -g -Wall -fPIC -I. -I../O.Common -I. -I. -I..
> -I./../include/compiler/gcc -I./../include/os/Linux -I./../include
> -I/home/fpga/epics/base-3.16.2/include/compiler/gcc
> -I/home/fpga/epics/base-3.16.2/include -c ../mmapDrv.c
> ../mmapDrv.c:9:10: fatal error: regDev.h: No existe el fichero o el
> directorio
> #include <regDev.h>
> make[1]: *** [/home/fpga/epics/base-3.16.2/configure/RULES_BUILD:235:
> mmapDrv.o] Error 1
> make[1]: se sale del directorio '/home/fpga/iocApp/mmap/O.linux-arm'
> make: *** [/home/fpga/epics/base-3.16.2/configure/RULES_ARCHS:58:
> install.linux-arm] Error 2
> fpga@debian10-zcu102:~/iocApp/regdev$ make
> If you are not using the PSI build environment, GNUmakefile can be removed.
> make[1]: se entra en el directorio '/home/fpga/iocApp/regdev/O.linux-arm'
> -I/home/fpga/epics/base-3.16.2/include -MM -MF simRegDev.d
> ../simRegDev.c
> ../simRegDev.c:18:10: fatal error: memDisplay.h: No existe el fichero
> o el directorio
> #include "memDisplay.h"
> -I/home/fpga/epics/base-3.16.2/include -MM -MF regDev.d
> ../regDev.c
> ../regDev.c:21:10: fatal error: memDisplay.h: No existe el fichero o
> el directorio
> -I/home/fpga/epics/base-3.16.2/include -c ../regDev.c
> /home/fpga/epics/base-3.16.2/include/dbAccess.h:19,
> from ../regDev.c:10:
> /home/fpga/epics/base-3.16.2/include/dbBase.h:162:5: warning: 'rset'
> is deprecated [-Wdeprecated-declarations]
> rset *prset;
> /home/fpga/epics/base-3.16.2/include/dbBase.h:21,
> from
> /home/fpga/epics/base-3.16.2/include/recSup.h:67:8: note: declared
> here
> struct rset { /* record support entry table */
> /home/fpga/epics/base-3.16.2/include/dbAccess.h:23,
> /home/fpga/epics/base-3.16.2/include/dbAccessDefs.h:208:46: warning:
> 'rset' is deprecated [-Wdeprecated-declarations]
> epicsShareFunc rset * dbGetRset(const struct dbAddr *paddr);
> from
> here
> el directorio
> regDev.o] Error 1
> make[1]: se sale del directorio '/home/fpga/iocApp/regdev/O.linux-arm'
- Re: Xilinx ARM64 mmap and regdev module compile error Ralph Lange via Tech-talk
- Xilinx ARM64 mmap and regdev module compile error Ha, Kiman via Tech-talk
- Re: Xilinx ARM64 mmap and regdev module compile error Jeong Han Lee via Tech-talk
Re: I can't figure out how to change the rate guarantee... Michael Davidsaver via Tech-talk
<2019>
<2019>
