1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024
Subject: Linux DMA driver and device support for Xilinx FPGA
From: "Ha, Kiman via Tech-talk" <[email protected]>
Date: Sat, 9 Nov 2019 22:22:03 +0000
Hello,
I am looking for the DMA driver and epics device support module for the Xilinx Zynq and Zynq ultrascal+ core.
Does anyone have to experience generic DMA support for the  Xilinx Zynq or Zynq ultrascal+ core or have a plan for the development?
For example, we developed four channel 500 MHz digitizer for the bunch by bunch beam position monitor (performance looks good, < 300 nm turn by tune position for the NSLS-II).
Currently, prototype supports an FPGA logic block ram (BRAM, 8 K/16 K * 16bit * 4, 500MHz clock rate) .
I have plan provides at least 1 M * 16bit * 4)  or 2 M points from the external DDR3/4 memory (FPGA side we implemented DMA core, but Linux part needs help) .
Because our physics group wants to minimum 1000 turns BxB position data.
If we have an epics device support, that’s very valuable for many diagnostics applications, especially beam diagnostics and physics applications.
Kiman
Re: Linux DMA driver and device support for Xilinx FPGA Mooney, Tim M. via Tech-talk
Re: Linux DMA driver and device support for Xilinx FPGA Hinko Kocevar via Tech-talk
Prev: Re: Xilinx ARM64 mmap and regdev module compile error Ralph Lange via Tech-talk
Next: Re: Linux DMA driver and device support for Xilinx FPGA Mooney, Tim M. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024
ANJ, 11 Nov 2019 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
