1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024
Subject: Re: RTEMS+EPICS NFS mount issue
From: Heinz Junkes via Tech-talk <[email protected]>
To: 刘峰瑞 <[email protected]>
Cc: Zhu <[email protected]>, tech-talk <[email protected]>
Date: Fri, 15 Nov 2019 20:58:11 +0100
how is the mount point provided?
by motload env?
by bootp?
Is the nfs server running?
What do the logs on the server show?
Heinz
> On 15. Nov 2019, at 03:46, 刘峰瑞 via Tech-talk <[email protected]> wrote:
> Hi Mr Zhu,
> I am a engineer for the RTEMS+EPICS to mvme5500 board.
> I meet the same problem of you listed in https://epics.anl.gov/tech-talk/2012/msg00186.php    when I mount the NFS server.
> The error infromation is listed below:
> RPCIO: SEND failure
> Unable to contact NFS server - invalid port? (RPC: Unable to send)
> nfsMount - mount: Unknown protocol
> How can I solve this problem ?
> Best regards,
> Fengui Liu
> E:   [email protected]
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: RTEMS+EPICS NFS mount issue Till Straumann via Tech-talk
Fw:RTEMS+EPICS NFS mount issue 刘峰瑞 via Tech-talk
Prev: Re: EPICS_AR_PORT Johnson, Andrew N. via Tech-talk
Next: Re: RTEMS+EPICS NFS mount issue Till Straumann via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024
Prev: Re: Fw:RTEMS+EPICS NFS mount issue Benjamin Franksen via Tech-talk
ANJ, 15 Nov 2019 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
