1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024
Subject: RE: Uploading a file with SFTP from an EPICS driver
To: "'J. Lewis Muir'" <[email protected]>
Date: Mon, 18 Nov 2019 14:03:57 +0000
Hi Lewis,
Ø  Strange.  Other things you could try:
    1. Run curl and curl_gen under strace (e.g., "strace -CftT -s 256
       <command>") and see if you can tell where curl_gen is taking longer
       than curl.
This is the final output of strace when running curl_gen:
07:55:27 +++ exited with 0 +++
% time     seconds  usecs/call     calls    errors syscall
34.38    0.000722           3       224       186 open
17.76    0.000373           4       102           mmap
13.00    0.000273           4        70           mprotect
  7.05    0.000148           3        57        23 recvfrom
  5.76    0.000121           3        39           fstat
  4.95    0.000104           3        40           read
  4.90    0.000103           5        22           poll
  3.57    0.000075           2        39           close
  2.38    0.000050           3        16           sendto
  2.10    0.000044           2        24           write
  0.90    0.000019          19         1           getsockopt
  0.67    0.000014           2         7           brk
  0.52    0.000011           4         3           munmap
  0.48    0.000010           0        23        18 stat
  0.29    0.000006           3         2         2 statfs
  0.24    0.000005           1         4         2 access
  0.19    0.000004           1         3           fcntl
  0.14    0.000003           1         3           rt_sigaction
  0.14    0.000003           3         1           getsockname
  0.14    0.000003           3         1           getpeername
  0.10    0.000002           2         1           rt_sigprocmask
  0.10    0.000002           2         1           getrlimit
  0.05    0.000001           1         1           lseek
  0.05    0.000001           1         1           getuid
  0.05    0.000001           1         1           arch_prctl
  0.05    0.000001           1         1           set_tid_address
  0.05    0.000001           1         1           set_robust_list
  0.00    0.000000           0         1           socket
  0.00    0.000000           0         1         1 connect
  0.00    0.000000           0         3           setsockopt
  0.00    0.000000           0         1           execve
  0.00    0.000000           0         1           gettid
  0.00    0.000000           0         1           futex
100.00    0.002100                   696       232 total
This is the output of strace when running the curl command:
07:55:53 +++ exited with 0 +++
57.74    0.001797           4       453           write
  8.16    0.000254           5        55        21 recvfrom
  7.33    0.000228           4        54           rt_sigaction
  5.82    0.000181          10        18           poll
  3.47    0.000108           7        16           sendto
  2.96    0.000092           3        28           mprotect
  2.12    0.000066           1        72        51 open
  1.90    0.000059           3        22           read
  1.83    0.000057           1        67           mmap
  1.74    0.000054           4        15           futex
  1.35    0.000042           2        25           close
  1.06    0.000033           4         8           brk
  0.64    0.000020           7         3           munmap
  0.61    0.000019           1        30        25 stat
  0.55    0.000017           1        21           fstat
  0.32    0.000010           3         3           fcntl
  0.26    0.000008           4         2           socket
  0.26    0.000008           8         1         1 connect
  0.22    0.000007           2         4           setsockopt
  0.19    0.000006           3         2         1 access
  0.16    0.000005           5         1           pipe
  0.13    0.000004           4         1           select
  0.13    0.000004           4         1           getsockopt
  0.10    0.000003           3         1           lseek
  0.10    0.000003           3         1           rt_sigprocmask
  0.10    0.000003           3         1           getsockname
  0.10    0.000003           3         1           getpeername
  0.10    0.000003           3         1           arch_prctl
  0.10    0.000003           3         1           set_tid_address
  0.10    0.000003           3         1           set_robust_list
  0.06    0.000002           2         1           ioctl
  0.06    0.000002           2         1           getrlimit
  0.06    0.000002           2         1           getuid
  0.06    0.000002           2         1           getgid
  0.06    0.000002           2         1           geteuid
  0.06    0.000002           2         1           getegid
  0.00    0.000000           0         1           readlink
100.00    0.003112                   917        99 total
I don’t know how to interpret these because the total elapsed time for curl_gen was 0.33 seconds while for the curl command it was 0.12 seconds.  The tables above seem to show only 2-3 ms?
     2. Check the compiler optimization level curl_gen is compiled at just
       in case it's weak compared to what I presume the curl executable was
      compiled at.  (I doubt this is the cause.)
That cannot be the problem.  All of the elapsed time in curl_gen is spent in the single call to curl_perform, which is not in curl_gen, but rather in the libcurl package.
    3. Check the ldd output for curl, libcurl.so, and curl_gen for anything
        that looks suspicious.  Make sure curl_gen is not linked against
        libgnutls.
corvette:motorNewport/newportApp/src>ldd ../../../../bin/linux-x86_64/curl_gen
        linux-vdso.so.1 =>  (0x00007ffe0e3dc000)
        libcurl.so.4 => /lib64/libcurl.so.4 (0x00007f0faff52000)
        libstdc++.so.6 => /lib64/libstdc++.so.6 (0x00007f0fafc4b000)
        libm.so.6 => /lib64/libm.so.6 (0x00007f0faf949000)
        libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007f0faf733000)
        libc.so.6 => /lib64/libc.so.6 (0x00007f0faf366000)
        libidn.so.11 => /lib64/libidn.so.11 (0x00007f0faf133000)
        libssh2.so.1 => /lib64/libssh2.so.1 (0x00007f0faef06000)
        libssl3.so => /lib64/libssl3.so (0x00007f0faecb4000)
        libsmime3.so => /lib64/libsmime3.so (0x00007f0faea8d000)
        libnss3.so => /lib64/libnss3.so (0x00007f0fae760000)
        libnssutil3.so => /lib64/libnssutil3.so (0x00007f0fae531000)
        libplds4.so => /lib64/libplds4.so (0x00007f0fae32d000)
        libplc4.so => /lib64/libplc4.so (0x00007f0fae128000)
        libnspr4.so => /lib64/libnspr4.so (0x00007f0fadeea000)
        libpthread.so.0 => /lib64/libpthread.so.0 (0x00007f0fadcce000)
        libdl.so.2 => /lib64/libdl.so.2 (0x00007f0fadaca000)
        libgssapi_krb5.so.2 => /lib64/libgssapi_krb5.so.2 (0x00007f0fad87d000)
        libkrb5.so.3 => /lib64/libkrb5.so.3 (0x00007f0fad594000)
        libk5crypto.so.3 => /lib64/libk5crypto.so.3 (0x00007f0fad361000)
        libcom_err.so.2 => /lib64/libcom_err.so.2 (0x00007f0fad15d000)
        liblber-2.4.so.2 => /lib64/liblber-2.4.so.2 (0x00007f0facf4e000)
        libldap-2.4.so.2 => /lib64/libldap-2.4.so.2 (0x00007f0faccf9000)
        libz.so.1 => /lib64/libz.so.1 (0x00007f0facae3000)
        /lib64/ld-linux-x86-64.so.2 (0x00007f0fb01bc000)
        libssl.so.10 => /lib64/libssl.so.10 (0x00007f0fac871000)
        libcrypto.so.10 => /lib64/libcrypto.so.10 (0x00007f0fac40e000)
        librt.so.1 => /lib64/librt.so.1 (0x00007f0fac206000)
        libkrb5support.so.0 => /lib64/libkrb5support.so.0 (0x00007f0fabff6000)
        libkeyutils.so.1 => /lib64/libkeyutils.so.1 (0x00007f0fabdf2000)
        libresolv.so.2 => /lib64/libresolv.so.2 (0x00007f0fabbd9000)
        libsasl2.so.3 => /lib64/libsasl2.so.3 (0x00007f0fab9bc000)
        libselinux.so.1 => /lib64/libselinux.so.1 (0x00007f0fab795000)
        libcrypt.so.1 => /lib64/libcrypt.so.1 (0x00007f0fab55e000)
        libpcre.so.1 => /lib64/libpcre.so.1 (0x00007f0fab2fc000)
        libfreebl3.so => /lib64/libfreebl3.so (0x00007f0fab0f9000)
    4. You usually build EPICS and modules from an NFS file system,
       right?  Is that the case here?  If so, try copying curl_gen (and any
      dependencies) to a non-network file system and running it there.
This test was run on corvette, which is our Linux file server.  So the programs are on the local file system, not NFS.
-----Original Message-----
Sent: Friday, November 15, 2019 1:05 PM
Cc: [email protected]
Subject: Re: Uploading a file with SFTP from an EPICS driver
On 11/15, Mark Rivers wrote:
> Thanks for the suggestion.  Now things get REALLY weird.
Indeed. :-)
> I did what you said, and ran curl with --libcurl.  I timed the command:
[snip]
> The performance was the same, 0.33 seconds, much slower than running the curl command itself!
   than curl.
   libgnutls.
Lewis
Re: Uploading a file with SFTP from an EPICS driver Torsten Bögershausen via Tech-talk
Re: Uploading a file with SFTP from an EPICS driver J. Lewis Muir via Tech-talk
Uploading a file with SFTP from an EPICS driver Mark Rivers via Tech-talk
RE: Uploading a file with SFTP from an EPICS driver Mark Rivers via Tech-talk
Prev: RE: ../../bin/linux-x86_64/testIOC: bad interpreter: No such file or directory Mark Rivers via Tech-talk
Next: ai records with data covering many decades Bo Jakobsen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024
Prev: Re: Uploading a file with SFTP from an EPICS driver J. Lewis Muir via Tech-talk
Next: Re: Uploading a file with SFTP from an EPICS driver Torsten Bögershausen via Tech-talk
ANJ, 18 Nov 2019 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
