We used to archive the log value, but now I use a calcout record to dynamically calculate the ADEL value.
Specifically I set the ADEL value to 1% of the just measured pressure value.
Cheers
Andrew Starritt
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of Maren Purves via Tech-talk
Sent: Tuesday, 19 November 2019 7:22 AM
To: Jemian, Pete R. <[email protected]>; Kasemir, Kay via Tech-talk <[email protected]>; Bo Jakobsen <[email protected]>
Subject: Re: [EXTERNAL] ai records with data covering many decades
We put in an extra record to calculate the logarithm and archive that
(same application: vacuum).
Maren Purves
East Asian Observatory/JCMT
On 2019-11-18 07:08, Jemian, Pete R. via Tech-talk wrote:
> To archive a signal that ranges over many decades, separate the mantissa and exponent into two separate values, each to be logged.
> Pete R. Jemian, Ph.D. <[email protected]>
> Beam line Controls and Data Acquisition
> Advanced Photon Source, Argonne National Laboratory
> Argonne, IL 60439 630 - 252 - 3189
> Education is the one thing for which people
> are willing to pay yet not receive.
> From: Tech-talk <[email protected]> on behalf of Kasemir, Kay via Tech-talk <[email protected]>
> Sent: Monday, November 18, 2019 8:51 AM
> To: EPICS tech-talk; Bo Jakobsen
> Hi:
>> ..PV for a pressure gauge which by nature covers many decades of values.
>> I wanted to set up MEDM and ADEL values before starting to log the values to our archiver.
>> Output is in exponential format, and i would like to monitor on e.g. 1 decimal independent of the exponent, it this possible.
> I'm not aware of a good solution for efficiently displaying or archiving log-scale-type-PVs via MDEL respectively ADEL.
> As you say, end users would like to see updates based on for example changes of "0.1", no matter if that's "0.1E-3" or "0.1E-5" on a log scale plot of vacuum pressure readings.
> Sometimes the MDEL/ADEL is set to say "0.1E-5" because the reading happened to be in the E-5 range at the time, and then the vacuum improves to the E-6 range and MDEL/ADEL suppresses all updates.
> So the only practical solution for archiving is to set ADEL=0, and store the value every few seconds to limit the amount of data. That's OK for the longer-term histor, but with vacuum readings you tend to care about some detail in vacuum excursions which start as a sharp spike, followed by exponential decay. With just a value every few seconds, you miss the initial spike detail.
> Thanks,
> Kay
RE: Uploading a file with SFTP from an EPICS driver Mark Rivers via Tech-talk
Re: EPICS Codeathon 2020 Gabriel Fedel via Tech-talk
<2019>
RE: areaDetector-R3-4, Stats Plugin - Histogram Mark Rivers via Tech-talk
EPICS server won't boot when there is no newline at the ending of st.cmd 黄佳伟 via Tech-talk
<2019>
