What is the period, duration and allowable jitter on the input trigger signal?
The reason I ask is that the Zebra, PandA ( https://quantumdetectors.com/n/products/pandabox/) and possibly softGlue register input signals using an internal clock (50MHz for Zebra, 125MHz for PandA).
This means that a jitter of up to the clock period will be applied if the trigger source is not synchronous with the FPGA's clock source. This won't impact slow signals, but if you are trying to synchronize a laser with a bunch pattern then nanoseconds of
jitter matter.
On the plus side, if you are looking at delays which are multiples of the FPGA clock period then Zebra, PandA and probably softGlue can also give you this functionality without needing the DG645...
Tom
Hi there.
I am looking for some suggestions for a device that would let me
(through epics) choose between different sources of pulse triggers.
In our beamline, we have a delay generator (DG645) from SRS to
synchronize multiple devices during acquisition with 1 input and 4
outputs. Since we have different devices that act as trigger source on
different experiments, our solution now is to change cables that
connects to our single input of the delay generator.
Is there a device with EPICS support that would allow me to manage this
triggering source?
Thank you.
Nilson Pereira.
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech (Sprecher), Prof. Dr. Jan Lüning, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail. Any opinions expressed within this e-mail are those of the individual and not necessarily of Diamond Light Source Ltd. Diamond Light Source Ltd. cannot guarantee that this e-mail or any attachments are free from viruses and we cannot accept liability for any damage which you may sustain as a result of software viruses which may be transmitted in or with the message. Diamond Light Source Limited (company no. 4375679). Registered in England and Wales with its registered office at Diamond House, Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom
