Maybe the following patch is needed for Ubuntu, because it is needed
for Debian.
https://github.com/jeonghanlee/extensions/blob/master/patches/Xp_is_not_needed.p0.patch
Best,
Han
On 2019-11-27 01:03, William Layne via Tech-talk wrote:
I'm not sure if it's the x86 config file, but we had the same problem
and this fixed it at our site.
On Tue, Nov 26, 2019, 6:15 PM Soliday, Robert T. via Tech-talk
<[email protected] <mailto:[email protected]>> wrote:
I believe you will have to modify
extensions/configure/os/CONFIG_SITE.linux-x86.linux-x86
The MOTIF_LIB and MOTIF_INC probably need to be changed.
--Bob Soliday
On 11/26/19 5:01 PM, Mark Rivers via Tech-talk wrote:
Folks,____
__ __
I am trying to get help Peiyu get medm running on Ubuntu. He has
installed libmotif-devel, and that has installed libXm.a and
libXm.so in /usr/lib/x86_64-linux-gnu/. I was not sure if Ubuntu
was searching that directory by default, so just to be sure I had
him set LD_LIBRARY_PATH to point to it.____
This is that directory:____
epics0@ubuntu:~/Apps/epics/base/lib/linux-x86_64$ ls -l
$LD_LIBRARY_PATH/libXm*
-rw-r--r-- 1 root root 4677026 Feb 19 2018
/usr/lib/x86_64-linux-gnu/libXm.a
lrwxrwxrwx 1 root root 14 Feb 19 2018
/usr/lib/x86_64-linux-gnu/libXm.so -> libXm.so.4.0.4
/usr/lib/x86_64-linux-gnu/libXm.so.3 -> libXm.so.4.0.4
/usr/lib/x86_64-linux-gnu/libXm.so.4 -> libXm.so.4.0.4
-rw-r--r-- 1 root root 2886704 Feb 19 2018
/usr/lib/x86_64-linux-gnu/libXm.so.4.0.4
-rw-r--r-- 1 root root 201152 Dec 10 2015
/usr/lib/x86_64-linux-gnu/libXmu.a
lrwxrwxrwx 1 root root 15 Dec 10 2015
/usr/lib/x86_64-linux-gnu/libXmu.so -> libXmu.so.6.2.0
lrwxrwxrwx 1 root root 15 Sep 3 08:09
/usr/lib/x86_64-linux-gnu/libXmu.so.6 -> libXmu.so.6.2.0
-rw-r--r-- 1 root root 102824 Dec 10 2015
/usr/lib/x86_64-linux-gnu/libXmu.so.6.2.0
lrwxrwxrwx 1 root root 16 Sep 3 08:09
/usr/lib/x86_64-linux-gnu/libXmuu.so.1 -> libXmuu.so.1.0.0
-rw-r--r-- 1 root root 14528 Dec 10 2015
/usr/lib/x86_64-linux-gnu/libXmuu.so.1.0.0____
__ __
However, when he builds medm he still gets this:____
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE
-D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DSCIPLOT
-DMOTIF -DEDITRES -mtune=generic -m64 -I. -I../O.Common -I.
-I. -I.. -I../../../../include/compiler/gcc
-I../../../../include/os/Linux -I../../../../include
-I../../../../../base/include/compiler/gcc
-I../../../../../base/include/os/Linux
-I../../../../../base/include -I../../printUtils -I../../xc
-I/usr/include -I/usr/include -c ../xgif.c
make[2]: *** No rule to make target
'../../../../lib/linux-x86_64/libXm.a', needed by 'medm'. Stop.
make[2]: Leaving directory
'/home/epics0/Apps/epics/extensions/src/medm-master/medm/O.linux-x86_64'
../../../../base/configure/RULES_ARCHS:58: recipe for target
'install.linux-x86_64' failed
make[1]: *** [install.linux-x86_64] Error 2
make[1]: Leaving directory
'/home/epics0/Apps/epics/extensions/src/medm-master/medm'
../../../base/configure/RULES_DIRS:84: recipe for target
'medm.install' failed
make: *** [medm.install] Error 2____
__ __
Any ideas?____
__ __
Thanks,____
Mark____
__ __
- RE: MEDM install result Mark Rivers via Tech-talk
- Re: MEDM install result Soliday, Robert T. via Tech-talk
- Re: MEDM install result William Layne via Tech-talk
Accessing IOC on different subnet Bhavna N. Merh via Tech-talk
<2019>
Re: MEDM install result Torsten Bögershausen via Tech-talk
<2019>
ANJ, 27 Nov 2019 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
