On 1/5/20 6:33 PM, Mark Rivers wrote:
>> Are any of the 10G links fiber?
> I have tested with 2 different Linux machines. On one of them the link from the Linux machine to the first switch is fiber, on the other it is copper. Both fail the same way. I have also tested 2 different devices that are connected to different 1 Gbit switches with (obviously) different cables. So I don't think it is a defective cable or switch. I would also point out that the problem is not at all random, it is completely deterministic. Each time I send a specific packet I get a frame error on the NIC, which does not sound like collisions to me?
>> I suspect that if you were able to eliminate the switches, and connect a 10G NIC directly to the device, things would work.
>> Or fail explicitly with no link if auto-negotiation isn't working.
> My understanding what you propose is impossible. I have not seen any 10 Gbit copper NICs that support 10 Mbit. They all say they only support 10000/1000/100 Mbit. The same is true for the 10 Gbit switches I have seen. In order to physically connect the device to a 10 Gbit NIC I believe I need at a minimum a 1 Gbit switch.
> Have you seen 10 Gbit NICs that can directly connect to a 10 Mbit device?
Forgive me Mark, the last time I had a 10M ethernet NIC in my hand I was dealing
with Windows 3.1.1 and IPX protocol. And I was removing it after lighting damage
(it would transmit, but not receive).
I suspect that the host side difference you describe is a symptom of a problem
between the device and the switch it is directly connected to. I shouldn't be
theorizing further on so little information, so I'll leave it at that.
- RE: Ethernet question Mark Rivers via Tech-talk
- Re: Ethernet question Michael Davidsaver via Tech-talk
- Re: Ethernet question Mark Rivers via Tech-talk
Re:RE: help for streamDevice question 张亚威 via Tech-talk
EPID record Vishnu Patel via Tech-talk
<2020>
Re: Ethernet question J. Lewis Muir via Tech-talk
<2020>
