Dear All, I installed the following softwares on the Windows_7_x64 system: * Microsoft Visual Studio Community 2019 * Strawberry-perl-5.30.1.1 * EPICS base-7.0.3.1 * Hummingbird Exceed v13 * EPICSWindowsTools1.44-x64.msi ==================================== The problem is: I can run IOC and edit MEDM normally. But, when I execute a MEDM, the MEDM responds to the button events very slowly, although displaying PVs normally. When I switch to edit mode, the MEDM disconnects with IOCs and is stuck . At this time, I can new a MEDM and edit it normally. But when I switch it to execute mode, the same problem would happen immediately. ==================================== Have others seen similar problems? What could be wrong? Thanks, Yang
ANJ, 20 Feb 2020 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
