![]() /opt/epics/synApps/support/areaDetector-master/ADAravis/iocs/aravisIOC/iocBoot/iocAravis# ../../bin/linux-x86_64/ADAravisApp st.cmd < envPaths epicsEnvSet("IOC","iocAravis") epicsEnvSet("TOP","/opt/epics/synApps/support/areaDetector-master/ADAravis/iocs/aravisIOC") epicsEnvSet("ADARAVIS","/opt/epics/synApps/support/areaDetector-master/ADAravis/iocs/aravisIOC/../..") epicsEnvSet("SUPPORT","/opt/epics/synApps/support") epicsEnvSet("ASYN","/opt/epics/synApps/support/asyn-R4-38") epicsEnvSet("AREA_DETECTOR","/opt/epics/synApps/support/areaDetector-master") epicsEnvSet("ADSUPPORT","/opt/epics/synApps/support/areaDetector-master/ADSupport") epicsEnvSet("ADCORE","/opt/epics/synApps/support/areaDetector-master/ADCore") epicsEnvSet("AUTOSAVE","/opt/epics/synApps/support/autosave-R5-10") epicsEnvSet("BUSY","/opt/epics/synApps/support/busy-R1-7-2") epicsEnvSet("CALC","/opt/epics/synApps/support/calc-R3-7-3") epicsEnvSet("SNCSEQ","/opt/epics/synApps/support/seq-2-2-6") epicsEnvSet("SSCAN","/opt/epics/synApps/support/sscan-R2-11-3") epicsEnvSet("DEVIOCSTATS","/opt/epics/synApps/support/iocStats-3-1-16") epicsEnvSet("EPICS_BASE","/opt/epics/base") epicsEnvSet("ADGENICAM","/opt/epics/synApps/support/areaDetector-master/ADGenICam") errlogInit(20000) dbLoadDatabase("/opt/epics/synApps/support/areaDetector-master/ADAravis/iocs/aravisIOC/dbd/ADAravisApp.dbd") ADAravisApp_registerRecordDeviceDriver(pdbbase) # Name of camera as reported by arv-tool epicsEnvSet("CAMERA_NAME", 10.0.0.230) # The maximum image width; used for row profiles in the NDPluginStats plugin epicsEnvSet("XSIZE", "2304") # The maximum image height; used for column profiles in the NDPluginStats plugin epicsEnvSet("YSIZE", "1300") # Define NELEMENTS to be enough for a 2464x2056x3 (color) image epicsEnvSet("NELEMENTS", "2995200") # Enable register caching epicsEnvSet("ENABLE_CACHING", "1") # The database file epicsEnvSet("GENICAM_DB_FILE", "/opt/epics/synApps/support/areaDetector-master/ADGenICam/GenICamApp/Db/Teledyne_ShadoBox.template") < st.cmd.base # Prefix for all records epicsEnvSet("PREFIX", "ARV1:") # The port name for the detector epicsEnvSet("PORT", "ARV1") # Really large queue so we can stream to disk at full camera speed epicsEnvSet("QSIZE", "2000") # The maximum number of time series points in the NDPluginStats plugin epicsEnvSet("NCHANS", "2048") # The maximum number of frames buffered in the NDPluginCircularBuff plugin epicsEnvSet("CBUFFS", "500") # The search path for database files epicsEnvSet("EPICS_DB_INCLUDE_PATH", "/opt/epics/synApps/support/areaDetector-master/ADCore/db:/opt/epics/synApps/support/areaDetector-master/ADGenICam/GenICamApp/Db:/opt/epics/synApps/support/areaDetector-master/ADAravis/iocs/aravisIOC/../../db") # aravisConfig(const char *portName, const char *cameraName, int enableCaching, size_t maxMemory, int priority, int stackSize) aravisConfig("ARV1", "10.0.0.230", 1, 0, 0, 0) ADAravis: Looking for camera '10.0.0.230'... ADAravis: Your tick frequency is 1000000 So your timestamp resolution is 1000.000000 ns asynSetTraceIOMask(ARV1, 0, 2) #asynSetTraceMask($(PORT), 0, TRACE_ERROR|TRACEIO_DRIVER|TRACE_FLOW) #asynSetTraceFile($(PORT), 0, "aravisDebug.txt") # Main database dbLoadRecords("/opt/epics/synApps/support/areaDetector-master/ADAravis/iocs/aravisIOC/../../db/aravisCamera.template", "P=ARV1:,R=cam1:,PORT=ARV1") # Load the autogenerated file of GenICam features dbLoadRecords("/opt/epics/synApps/support/areaDetector-master/ADGenICam/GenICamApp/Db/Teledyne_ShadoBox.template", "P=ARV1:,R=cam1:,PORT=ARV1") # Create a standard arrays plugin NDStdArraysConfigure("Image1", 5, 0, "ARV1", 0, 0) # Use this line for 8-bit data only #dbLoadRecords("$(ADCORE)/db/NDStdArrays.template", "P=$(PREFIX),R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT),TYPE=Int8,FTVL=CHAR,NELEMENTS=$(NELEMENTS)") # Use this line for 8-bit or 16-bit data dbLoadRecords("/opt/epics/synApps/support/areaDetector-master/ADCore/db/NDStdArrays.template", "P=ARV1:,R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1,TYPE=Int16,FTVL=SHORT,NELEMENTS=2995200") # Load all other plugins using commonPlugins.cmd < /opt/epics/synApps/support/areaDetector-master/ADCore/iocBoot/commonPlugins.cmd # This is an example file for creating plugins # It uses the following environment variable macros # Many of the parameters defined in this file are also in commonPlugins_settings.req so if autosave is being # use the autosave value will replace the value passed to this file. # $(PREFIX) Prefix for all records # $(PORT) The port name for the detector. In autosave. # $(QSIZE) The queue size for all plugins. In autosave. # $(XSIZE) The maximum image width; used to set the maximum size for row profiles in the NDPluginStats plugin and 1-D FFT # profiles in NDPluginFFT. # $(YSIZE) The maximum image height; used to set the maximum size for column profiles in the NDPluginStats plugin # $(NCHANS) The maximum number of time series points in the NDPluginStats, NDPluginROIStats, and NDPluginAttribute plugins # $(CBUFFS) The maximum number of frames buffered in the NDPluginCircularBuff plugin # $(MAX_THREADS) The maximum number of threads for plugins which can run in multiple threads. Defaults to 5. # Create a netCDF file saving plugin NDFileNetCDFConfigure("FileNetCDF1", 2000, 0, "ARV1", 0) dbLoadRecords("NDFileNetCDF.template","P=ARV1:,R=netCDF1:,PORT=FileNetCDF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1") # Create a TIFF file saving plugin NDFileTIFFConfigure("FileTIFF1", 2000, 0, "ARV1", 0) dbLoadRecords("NDFileTIFF.template", "P=ARV1:,R=TIFF1:,PORT=FileTIFF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1") # Create a JPEG file saving plugin NDFileJPEGConfigure("FileJPEG1", 2000, 0, "ARV1", 0) dbLoadRecords("NDFileJPEG.template", "P=ARV1:,R=JPEG1:,PORT=FileJPEG1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1") # Create a NeXus file saving plugin NDFileNexusConfigure("FileNexus1", 2000, 0, "ARV1", 0) dbLoadRecords("NDFileNexus.template", "P=ARV1:,R=Nexus1:,PORT=FileNexus1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1") # Create an HDF5 file saving plugin NDFileHDF5Configure("FileHDF1", 2000, 0, "ARV1", 0) dbLoadRecords("NDFileHDF5.template", "P=ARV1:,R=HDF1:,PORT=FileHDF1,ADDR=0,TIMEOUT=1,XMLSIZE=2048,NDARRAY_PORT=ARV1") # Create a Magick file saving plugin #NDFileMagickConfigure("FileMagick1", $(QSIZE), 0, "$(PORT)", 0) #dbLoadRecords("NDFileMagick.template","P=$(PREFIX),R=Magick1:,PORT=FileMagick1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)") # Create 4 ROI plugins NDROIConfigure("ROI1", 2000, 0, "ARV1", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDROI.template", "P=ARV1:,R=ROI1:, PORT=ROI1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1") NDROIConfigure("ROI2", 2000, 0, "ARV1", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDROI.template", "P=ARV1:,R=ROI2:, PORT=ROI2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1") NDROIConfigure("ROI3", 2000, 0, "ARV1", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDROI.template", "P=ARV1:,R=ROI3:, PORT=ROI3,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1") NDROIConfigure("ROI4", 2000, 0, "ARV1", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDROI.template", "P=ARV1:,R=ROI4:, PORT=ROI4,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1") # Create 8 ROIStat plugins NDROIStatConfigure("ROISTAT1", 2000, 0, "ARV1", 0, 8, 0, 0, 0, 0, 5) dbLoadRecords("NDROIStat.template", "P=ARV1:,R=ROIStat1: ,PORT=ROISTAT1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1,NCHANS=2048") dbLoadRecords("NDROIStatN.template", "P=ARV1:,R=ROIStat1:1:,PORT=ROISTAT1,ADDR=0,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDROIStatN.template", "P=ARV1:,R=ROIStat1:2:,PORT=ROISTAT1,ADDR=1,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDROIStatN.template", "P=ARV1:,R=ROIStat1:3:,PORT=ROISTAT1,ADDR=2,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDROIStatN.template", "P=ARV1:,R=ROIStat1:4:,PORT=ROISTAT1,ADDR=3,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDROIStatN.template", "P=ARV1:,R=ROIStat1:5:,PORT=ROISTAT1,ADDR=4,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDROIStatN.template", "P=ARV1:,R=ROIStat1:6:,PORT=ROISTAT1,ADDR=5,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDROIStatN.template", "P=ARV1:,R=ROIStat1:7:,PORT=ROISTAT1,ADDR=6,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDROIStatN.template", "P=ARV1:,R=ROIStat1:8:,PORT=ROISTAT1,ADDR=7,TIMEOUT=1,NCHANS=2048") # Create a processing plugin NDProcessConfigure("PROC1", 2000, 0, "ARV1", 0, 0, 0) dbLoadRecords("NDProcess.template", "P=ARV1:,R=Proc1:, PORT=PROC1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1") # Create a TIFF file plugin to read dark and flatfield images into the processing plugin NDFileTIFFConfigure("PROC1TIFF", 2000, 0, "ARV1", 0) dbLoadRecords("NDFileTIFF.template", "P=ARV1:,R=Proc1:TIFF:,PORT=PROC1TIFF,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1") # Create a scatter plugin NDScatterConfigure("SCATTER1", 2000, 0, "ARV1", 0, 0, 0) dbLoadRecords("NDScatter.template", "P=ARV1:,R=Scatter1:, PORT=SCATTER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1") # Create a gather plugin with 8 ports NDGatherConfigure("GATHER1", 2000, 0, 8, 0, 0) dbLoadRecords("NDGather.template", "P=ARV1:,R=Gather1:, PORT=GATHER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1") dbLoadRecords("NDGatherN.template", "P=ARV1:,R=Gather1:, N=1, PORT=GATHER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1") dbLoadRecords("NDGatherN.template", "P=ARV1:,R=Gather1:, N=2, PORT=GATHER1,ADDR=1,TIMEOUT=1,NDARRAY_PORT=ARV1") dbLoadRecords("NDGatherN.template", "P=ARV1:,R=Gather1:, N=3, PORT=GATHER1,ADDR=2,TIMEOUT=1,NDARRAY_PORT=ARV1") dbLoadRecords("NDGatherN.template", "P=ARV1:,R=Gather1:, N=4, PORT=GATHER1,ADDR=3,TIMEOUT=1,NDARRAY_PORT=ARV1") dbLoadRecords("NDGatherN.template", "P=ARV1:,R=Gather1:, N=5, PORT=GATHER1,ADDR=4,TIMEOUT=1,NDARRAY_PORT=ARV1") dbLoadRecords("NDGatherN.template", "P=ARV1:,R=Gather1:, N=6, PORT=GATHER1,ADDR=5,TIMEOUT=1,NDARRAY_PORT=ARV1") dbLoadRecords("NDGatherN.template", "P=ARV1:,R=Gather1:, N=7, PORT=GATHER1,ADDR=6,TIMEOUT=1,NDARRAY_PORT=ARV1") dbLoadRecords("NDGatherN.template", "P=ARV1:,R=Gather1:, N=8, PORT=GATHER1,ADDR=7,TIMEOUT=1,NDARRAY_PORT=ARV1") # Create 5 statistics plugins NDStatsConfigure("STATS1", 2000, 0, "ARV1", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDStats.template", "P=ARV1:,R=Stats1:, PORT=STATS1,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=2304,YSIZE=1300,NCHANS=2048,NDARRAY_PORT=ARV1") NDTimeSeriesConfigure("STATS1_TS", 2000, 0, "STATS1", 1, 23) dbLoadRecords("/opt/epics/synApps/support/areaDetector-master/ADCore/db/NDTimeSeries.template", "P=ARV1:,R=Stats1:TS:, PORT=STATS1_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS1,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1") NDStatsConfigure("STATS2", 2000, 0, "ROI1", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDStats.template", "P=ARV1:,R=Stats2:, PORT=STATS2,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=2304,YSIZE=1300,NCHANS=2048,NDARRAY_PORT=ARV1") NDTimeSeriesConfigure("STATS2_TS", 2000, 0, "STATS2", 1, 23) dbLoadRecords("/opt/epics/synApps/support/areaDetector-master/ADCore/db/NDTimeSeries.template", "P=ARV1:,R=Stats2:TS:, PORT=STATS2_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS2,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1") NDStatsConfigure("STATS3", 2000, 0, "ROI2", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDStats.template", "P=ARV1:,R=Stats3:, PORT=STATS3,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=2304,YSIZE=1300,NCHANS=2048,NDARRAY_PORT=ARV1") NDTimeSeriesConfigure("STATS3_TS", 2000, 0, "STATS3", 1, 23) dbLoadRecords("/opt/epics/synApps/support/areaDetector-master/ADCore/db/NDTimeSeries.template", "P=ARV1:,R=Stats3:TS:, PORT=STATS3_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS3,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1") NDStatsConfigure("STATS4", 2000, 0, "ROI3", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDStats.template", "P=ARV1:,R=Stats4:, PORT=STATS4,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=2304,YSIZE=1300,NCHANS=2048,NDARRAY_PORT=ARV1") NDTimeSeriesConfigure("STATS4_TS", 2000, 0, "STATS4", 1, 23) dbLoadRecords("/opt/epics/synApps/support/areaDetector-master/ADCore/db/NDTimeSeries.template", "P=ARV1:,R=Stats4:TS:, PORT=STATS4_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS4,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1") NDStatsConfigure("STATS5", 2000, 0, "ROI4", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDStats.template", "P=ARV1:,R=Stats5:, PORT=STATS5,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=2304,YSIZE=1300,NCHANS=2048,NDARRAY_PORT=ARV1") NDTimeSeriesConfigure("STATS5_TS", 2000, 0, "STATS5", 1, 23) dbLoadRecords("/opt/epics/synApps/support/areaDetector-master/ADCore/db/NDTimeSeries.template", "P=ARV1:,R=Stats5:TS:, PORT=STATS5_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS5,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1") # Create a transform plugin NDTransformConfigure("TRANS1", 2000, 0, "ARV1", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDTransform.template", "P=ARV1:,R=Trans1:, PORT=TRANS1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1") # Create an overlay plugin with 8 overlays NDOverlayConfigure("OVER1", 2000, 0, "ARV1", 0, 8, 0, 0, 0, 0, 5) dbLoadRecords("NDOverlay.template", "P=ARV1:,R=Over1:, PORT=OVER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1") dbLoadRecords("NDOverlayN.template","P=ARV1:,R=Over1:1:,NAME=ROI1, SHAPE=1,O=Over1:,XPOS=ARV1:ROI1:MinX_RBV,YPOS=ARV1:ROI1:MinY_RBV,XSIZE=ARV1:ROI1:SizeX_RBV,YSIZE=ARV1:ROI1:SizeY_RBV,PORT=OVER1,ADDR=0,TIMEOUT=1") dbLoadRecords("NDOverlayN.template","P=ARV1:,R=Over1:2:,NAME=ROI2, SHAPE=1,O=Over1:,XPOS=ARV1:ROI2:MinX_RBV,YPOS=ARV1:ROI2:MinY_RBV,XSIZE=ARV1:ROI2:SizeX_RBV,YSIZE=ARV1:ROI2:SizeY_RBV,PORT=OVER1,ADDR=1,TIMEOUT=1") dbLoadRecords("NDOverlayN.template","P=ARV1:,R=Over1:3:,NAME=ROI3, SHAPE=1,O=Over1:,XPOS=ARV1:ROI3:MinX_RBV,YPOS=ARV1:ROI3:MinY_RBV,XSIZE=ARV1:ROI3:SizeX_RBV,YSIZE=ARV1:ROI3:SizeY_RBV,PORT=OVER1,ADDR=2,TIMEOUT=1") dbLoadRecords("NDOverlayN.template","P=ARV1:,R=Over1:4:,NAME=ROI4, SHAPE=1,O=Over1:,XPOS=ARV1:ROI4:MinX_RBV,YPOS=ARV1:ROI4:MinY_RBV,XSIZE=ARV1:ROI4:SizeX_RBV,YSIZE=ARV1:ROI4:SizeY_RBV,PORT=OVER1,ADDR=3,TIMEOUT=1") dbLoadRecords("NDOverlayN.template","P=ARV1:,R=Over1:5:,NAME=Cursor1,SHAPE=1,O=Over1:,XPOS=junk, YPOS=junk, XSIZE=junk, YSIZE=junk, PORT=OVER1,ADDR=4,TIMEOUT=1") dbLoadRecords("NDOverlayN.template","P=ARV1:,R=Over1:6:,NAME=Cursor2,SHAPE=1,O=Over1:,XPOS=junk, YPOS=junk, XSIZE=junk, YSIZE=junk, PORT=OVER1,ADDR=5,TIMEOUT=1") dbLoadRecords("NDOverlayN.template","P=ARV1:,R=Over1:7:,NAME=Box1, SHAPE=1,O=Over1:,XPOS=junk, YPOS=junk, XSIZE=junk, YSIZE=junk, PORT=OVER1,ADDR=6,TIMEOUT=1") dbLoadRecords("NDOverlayN.template","P=ARV1:,R=Over1:8:,NAME=Box2, SHAPE=1,O=Over1:,XPOS=junk, YPOS=junk, XSIZE=junk, YSIZE=junk, PORT=OVER1,ADDR=7,TIMEOUT=1") # Create 2 color conversion plugins NDColorConvertConfigure("CC1", 2000, 0, "ARV1", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDColorConvert.template", "P=ARV1:,R=CC1:, PORT=CC1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1") NDColorConvertConfigure("CC2", 2000, 0, "ARV1", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDColorConvert.template", "P=ARV1:,R=CC2:, PORT=CC2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1") # Create a circular buffer plugin NDCircularBuffConfigure("CB1", 2000, 0, "ARV1", 0, 500, 0) dbLoadRecords("NDCircularBuff.template", "P=ARV1:,R=CB1:, PORT=CB1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ARV1") # Create an NDAttribute plugin with 8 attributes NDAttrConfigure("ATTR1", 2000, 0, "ARV1", 0, 8, 0, 0, 0) dbLoadRecords("NDAttribute.template", "P=ARV1:,R=Attr1:, PORT=ATTR1,ADDR=0,TIMEOUT=1,NCHANS=2048,NDARRAY_PORT=ARV1") dbLoadRecords("NDAttributeN.template", "P=ARV1:,R=Attr1:1:, PORT=ATTR1,ADDR=0,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDAttributeN.template", "P=ARV1:,R=Attr1:2:, PORT=ATTR1,ADDR=1,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDAttributeN.template", "P=ARV1:,R=Attr1:3:, PORT=ATTR1,ADDR=2,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDAttributeN.template", "P=ARV1:,R=Attr1:4:, PORT=ATTR1,ADDR=3,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDAttributeN.template", "P=ARV1:,R=Attr1:5:, PORT=ATTR1,ADDR=4,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDAttributeN.template", "P=ARV1:,R=Attr1:6:, PORT=ATTR1,ADDR=5,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDAttributeN.template", "P=ARV1:,R=Attr1:7:, PORT=ATTR1,ADDR=6,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDAttributeN.template", "P=ARV1:,R=Attr1:8:, PORT=ATTR1,ADDR=7,TIMEOUT=1,NCHANS=2048") NDTimeSeriesConfigure("ATTR1_TS", 2000, 0, "ATTR1", 1, 8) dbLoadRecords("/opt/epics/synApps/support/areaDetector-master/ADCore/db/NDTimeSeries.template", "P=ARV1:,R=Attr1:TS:, PORT=ATTR1_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ATTR1,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1") # Create an FFT plugin NDFFTConfigure("FFT1", 2000, 0, "ARV1", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDFFT.template", "P=ARV1:, R=FFT1:, PORT=FFT1, ADDR=0, TIMEOUT=1, NDARRAY_PORT=ARV1, NAME=FFT1, NCHANS=2304") # Create 2 Codec plugins NDCodecConfigure("CODEC1", 2000, 0, "ARV1", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDCodec.template", "P=ARV1:, R=Codec1:, PORT=CODEC1, ADDR=0, TIMEOUT=1, NDARRAY_PORT=ARV1") NDCodecConfigure("CODEC2", 2000, 0, "ARV1", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDCodec.template", "P=ARV1:, R=Codec2:, PORT=CODEC2, ADDR=0, TIMEOUT=1, NDARRAY_PORT=ARV1") set_requestfile_path("./") set_requestfile_path("/opt/epics/synApps/support/areaDetector-master/ADCore/ADApp/Db") set_requestfile_path("/opt/epics/synApps/support/areaDetector-master/ADCore/iocBoot") set_savefile_path("./autosave") set_pass0_restoreFile("auto_settings.sav") set_pass1_restoreFile("auto_settings.sav") save_restoreSet_status_prefix("ARV1:") dbLoadRecords("/opt/epics/synApps/support/autosave-R5-10/asApp/Db/save_restoreStatus.db", "P=ARV1:") # Optional: load NDPluginPva plugin #NDPvaConfigure("PVA1", $(QSIZE), 0, "$(PORT)", 0, $(PREFIX)Pva1:Image, 0, 0, 0) #dbLoadRecords("NDPva.template", "P=$(PREFIX),R=Pva1:, PORT=PVA1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)") # Must start PVA server if this is enabled #startPVAServer # Optional: load ffmpegServer plugin #ffmpegServerConfigure(8081) #ffmpegStreamConfigure("FfmStream1", 2, 0, "$(PORT)", 0, -1, 0) #dbLoadRecords("$(FFMPEGSERVER)/db/ffmpegStream.template", "P=$(PREFIX),R=ffmstream1:,PORT=FfmStream1,NDARRAY_PORT=$(PORT)") #ffmpegFileConfigure("FfmFile1", 16, 0, "$(PORT)", 0, -1, 0) #dbLoadRecords("$(FFMPEGSERVER)/db/ffmpegFile.template", "P=$(PREFIX),R=ffmfile1:,PORT=FfmFile1,NDARRAY_PORT=$(PORT)") # Optional: load NDPluginEdge plugin #NDEdgeConfigure("EDGE1", $(QSIZE), 0, "$(PORT)", 0, 0, 0, 0) #dbLoadRecords("$(ADPLUGINEDGE)/db/NDEdge.template", "P=$(PREFIX),R=Edge1:, PORT=EDGE1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)") #set_requestfile_path("$(ADPLUGINEDGE)/edgeApp/Db") # Optional: load NDPluginCV plugin #NDCVConfigure("CV1", $(QSIZE), 0, "$(PORT)", 0, 0, 0, 0, 0, $(MAX_THREADS=5)) #dbLoadRecords("$(ADCOMPVISION)/db/NDCV.template", "P=$(PREFIX),R=CV1:, PORT=CV1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)") #set_requestfile_path("$(ADCOMPVISION)/adcvApp/Db") # Optional: load NDPluginBar plugin #NDBarConfigure("BAR1", $(QSIZE), 0, "$(PORT)", 0, 0, 0, 0, 0, $(MAX_THREADS=5)) #dbLoadRecords("$(ADPLUGINBAR)/db/NDBar.template", "P=$(PREFIX),R=Bar1:, PORT=BAR1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)") #set_requestfile_path("$(ADPLUGINBAR)/barApp/Db") # Optional: load scan records #dbLoadRecords("$(SSCAN)/sscanApp/Db/scan.db", "P=$(PREFIX),MAXPTS1=2000,MAXPTS2=200,MAXPTS3=20,MAXPTS4=10,MAXPTSH=10") #set_requestfile_path("$(SSCAN)/sscanApp/Db") # Optional: load sseq record for acquisition sequence #dbLoadRecords("$(CALC)/calcApp/Db/sseqRecord.db", "P=$(PREFIX), S=AcquireSequence") #set_requestfile_path("$(CALC)/calcApp/Db") # Optional: load devIocStats records (requires DEVIOCSTATS module) #dbLoadRecords("$(DEVIOCSTATS)/db/iocAdminSoft.db", "IOC=$(PREFIX)") # Optional: load alive record (requires ALIVE module) #dbLoadRecords("$(ALIVE)/aliveApp/Db/alive.db", "P=$(PREFIX),RHOST=192.168.1.254") # Set the callback queue size to 5000, up from default of 2000 in base. # This can be needed to avoid errors "callbackRequest: cbLow ring buffer full". callbackSetQueueSize(5000) set_requestfile_path("/opt/epics/synApps/support/areaDetector-master/ADGenICam/GenICamApp/Db") set_requestfile_path("/opt/epics/synApps/support/areaDetector-master/ADAravis/iocs/aravisIOC/../../aravisApp/Db") iocInit() Starting iocInit ############################################################################ ## EPICS R3.15.6 ## EPICS Base built Feb 19 2020 ############################################################################ reboot_restore: entry for file 'auto_settings.sav' reboot_restore: Found filename 'auto_settings.sav' in restoreFileList. *** restoring from './autosave/auto_settings.sav' at initHookState 6 (before record/device init) *** reboot_restore: done with file 'auto_settings.sav' reboot_restore: entry for file 'auto_settings.sav' reboot_restore: Found filename 'auto_settings.sav' in restoreFileList. *** restoring from './autosave/auto_settings.sav' at initHookState 7 (after record/device init) *** reboot_restore: done with file 'auto_settings.sav' 2020/02/20 19:29:55.160 Param[NIMAGES] GenICamFeature::write: node AcquisitionFrameCount is not writable iocRun: All initialization complete # save things every thirty seconds create_monitor_set("auto_settings.req", 30,"P=ARV1:") Warning: Duplicate EPICS CA Address list entry "10.0.0.20:8174" discarded save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. epics> auto_settings.sav: 1284 of 1284 PV's connected In the ADAravis MEDM screen, when I try to acquire a single frame, it seems like the buffers fill up immediately (see attached image) and my image counter never increments. I tried adjusting the net.core.rmem_max and net.core.rmem_default settings to 8 MB but it did not make a difference. Any help is appreciated and please let me know what further information you may need; thanks! -Katie
ANJ, 20 Feb 2020 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
