1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Subject: String size limit for Eiger FileWriter when compiling with g++ > 5.2
From: "Wlodek, Jakub via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 4 Mar 2020 17:12:26 +0000
Hello all,
I have an interesting issue that I wanted to get some feedback on. One of our beamlines is running several Eiger detectors that were recently moved to a Debian 9 system,
and as soon as they were moved, we recieved feedback that the FileWriter was not saving the h5 files to the local storage.
After some testing, this was confirmed, however, only when the FilePattern PV was longer than 15 characters. The h5 file would be saved to the Eiger server and was visible
through the web interface, but was not copied to the local storage. Seeing as 15 characters was the limit, and the call sizeof(std::string) would return 15 with g++ > 5.2, we figured
out that somewhere there was an issue stemming from this, especially since on Debian 7 (g++ version 4.7.2) we did not see the problem.
I found that the following structure is sent on a message queue: epicsMessageQueue mPollQueue:
typedef struct
  string pattern;
    int sequenceId;
    size_t nDataFiles;
     bool saveFiles, parseFiles, removeFiles;
     mode_t filePerms;
}acquisition_t;
And calling pattern.c_str() before it was sent on the queue would print the full value, but on the recieve pattern.c_str() would be empty whenever the string
was longer than 15 characters. The queue was initialized with:
mPollQueue(1, sizeof(acquisition_t)),
My first idea was to simply increase the size of this second parameter for the epicsMessageQueue, but that did not solve the problem.
What did was changing the string pattern to char pattern[MAX_BUF_SIZE], and ensure that any time this pattern variable was called a conversion from string
to char[] was done.
My question is, is there a better way to fix this where the driver can continue to use std::string? And why did increasing the max transport size for the queue not
also fix the issue?
Jakub
Re: String size limit for Eiger FileWriter when compiling with g++ > 5.2 Bruno Martins via Tech-talk
Prev: Re: Problem during compilation of IOC with custom ADPlugin Wlodek, Jakub via Tech-talk
Next: Re: String size limit for Eiger FileWriter when compiling with g++ > 5.2 Bruno Martins via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Prev: Re: Problem during compilation of IOC with custom ADPlugin Gofron, Kazimierz via Tech-talk
ANJ, 06 Mar 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
