Hi All,
I am following the same procedure to do the autosave for V3 db records & V4 PVA records. My IOC looks similar to https://github.com/epics-base/exampleCPP/tree/master/database. Autosave lines in st.cmd are
set_requestfile_path("$(TOP)/autoSaverestore")
set_savefile_path("$(TOP)/autoSaverestore")
set_pass0_restoreFile("autosaverecord.sav")
set_pass1_restoreFile("autosaverecord.sav")
cd "${TOP}/iocBoot/${IOC}"
iocInit
create_monitor_set("autosaverecord.req", 5)
The output on epics console has error:
save_restore: connect failed for channel 'PVA_Double_Test'
“autosaverecord.req” file has both V3 & V4 record & has contents
PVA_Double_Test
CA_Double_Test
autosaverecord.sav file after autosave gives below contents
# autosave R5.3 Automatically generated - DO NOT MODIFY - 200902-193433
! 1 channel(s) not connected - or not all gets were successful
#PVA_Double_Test Search Issued
CA_Double_Test 8.9
<END>
So, the bottom line is autosave works for V3 type record but fails to do for V4 type PVA record. Any suggestion would be highly appreciated.
Many Thanks
Sandeep
