Hi Mark,
The constructor needed 64 bit mask. With correct mask, the 64 bit Integer PV works correctly as either ai, or int64in:
ADTimePix::ADTimePix(const char*
portName, const char*
serverURL, int maxBuffers,
size_t maxMemory,
int priority,
int stackSize
What helped was how 64bit mask was set in GenICam:
Warm regards,
Kaz
Sent: Friday, August 26, 2022 2:22 PM
To: Gofron, Kazimierz <kgofron at bnl.gov>; Torsten Bögershausen <Torsten.Bogershausen at ess.eu>
Cc: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: RE: setInteger64Param
Ø
I have different:
Ø
TIME: <undefined>
Ø
TSE : -2
That is OK, the values of those fields depends on which commands you uncomment in st.cmd. The main thing is that NSTA is NO_ALARM, so the link is OK.
This proves that asyn on your system is supporting int64In records with no errors in the asyn test IOC. The fact that it is not working in your areaDetector IOC means the problem
is probably in your build of the driver, or with the startup script.
Sent: Friday, August 26, 2022 1:16 PM
To: Mark Rivers <rivers at cars.uchicago.edu>; Torsten Bögershausen <Torsten.Bogershausen at ess.eu>
Subject: Re: setInteger64Param
There is no typo in the INP field, that I can see. The record loads without undefined macro in ioc.
epics> dbpr testErrors:Int64In 2
ACKS: NO_ALARM ACKT: YES ADEL: 0 AFTC: 0
AMSG: ASG : BKPT: 00 DESC:
DISA: 0 DISP: 0 DISS: NO_ALARM DISV: 1
DTYP: asynInt64 EGU : EVNT: FLNK: CONSTANT
HHSV: NO_ALARM HIGH: 0 HIHI: 0 HOPR: 0
INP : INST_IO @asyn(PORT1,0,1)INT64_VALUE LCNT: 0
LLSV: NO_ALARM LOLO: 0 LOPR: 0 LOW : 0
LSV : NO_ALARM MDEL: 0 NAME: testErrors:Int64In
NAMSG: NSEV: NO_ALARM NSTA: NO_ALARM PACT: 0
PHAS: 0 PINI: NO PRIO: LOW PUTF: 0
RPRO: 0 SCAN: I/O Intr SDIS: CONSTANT SDLY: -1
SEVR: NO_ALARM SIML: CONSTANT SIMM: NO SIMS: NO_ALARM
SIOL: CONSTANT SSCN: <nil> STAT: NO_ALARM SVAL: 0
TIME: <undefined> TPRO: 0 TSE : -2 TSEL: CONSTANT
UDF : 0 UDFS: INVALID VAL : 0
That version of base is fine.
Is there a typo in your INP field, or an undefined macro?
Did you check for error messages in iocInit?
You can test an int64In record by doing the following in asyn:
cd asyn/iocBoot/ioctestErrors
../../bin/linux-x86_64/testErrors st.cmd
HSV : NO_ALARM HYST: 0
RPRO: 0 SCAN: .1 second SDIS: CONSTANT SDLY: -1
TIME: 2022-08-26 12:54:22.190808469 TPRO: 0 TSE : 0
TSEL: CONSTANT UDF : 0 UDFS: INVALID VAL : 0
In this case the int64In record is working fine. What do you see?
kgofron@kgofron-HP-Z6-G4-Workstation:/epics/src/RHEL8/base$ git branch
* (HEAD detached at R7.0.6)
Hi Kaz,
dbpr shows a problem for both the ai and int64In records:
NSTA: LINK
PACT: 1
SEVR: INVALID
STAT: UDF
TIME: <undefined>
UDF : 1
The NSTA field (New Alarm Status) is LINK. This means there is something wrong with the input link.
What version of EPICS base are you using?
record(ai, "$(P)$(R)StartTime_RBV"){
field(INP, "@asyn($(PORT),$(ADDR),$(TIMEOUT))TPX3_START_TIME")
epics> dbpr TPX3-TEST:cam1:StartTime_RBV 2
AMSG: AOFF: 0 ASG : ASLO: 1
BKPT: 00 DESC: DISA: 0 DISP: 0
DISS: NO_ALARM DISV: 1 DTYP: asynInt64 EGU :
EGUF: 0 EGUL: 0 EOFF: 0 ESLO: 1
EVNT: FLNK: CONSTANT HHSV: NO_ALARM HIGH: 0
HIHI: 0 HOPR: 0 HSV : NO_ALARM HYST: 0
INP : INST_IO @asyn(TPX3,0,1)TPX3_START_TIME LCNT: 0
LINR: NO CONVERSION LLSV: NO_ALARM LOLO: 0 LOPR: 0
LOW : 0 LSV : NO_ALARM MDEL: 0
NAME: TPX3-TEST:cam1:StartTime_RBV NAMSG: NSEV: INVALID
NSTA: LINK PACT: 1 PHAS: 0 PINI: NO
PREC: 0 PRIO: LOW PUTF: 0 ROFF: 0
RPRO: 0 RVAL: 0 SCAN: Passive SDIS: CONSTANT
SDLY: -1 SEVR: INVALID SIML: CONSTANT SIMM: NO
SIMS: NO_ALARM SIOL: CONSTANT SMOO: 0 SSCN: <nil>
STAT: UDF SVAL: 0 TIME: <undefined> TPRO: 0
TSE : 0 TSEL: CONSTANT UDF : 1 UDFS: INVALID
Parameter 293 type=asynInt64, name=TPX3_START_TIME, value=1661466046253, status=0
record(int64in, "$(P)$(R)StartTime_RBV"){
LSV : NO_ALARM MDEL: 0 NAME: TPX3-TEST:cam1:StartTime_RBV
NAMSG: NSEV: INVALID NSTA: LINK PACT: 1
RPRO: 0 SCAN: Passive SDIS: CONSTANT SDLY: -1
SEVR: INVALID SIML: CONSTANT SIMM: NO SIMS: NO_ALARM
SIOL: CONSTANT SSCN: <nil> STAT: UDF SVAL: 0
TIME: <undefined> TPRO: 0 TSE : 0 TSEL: CONSTANT
UDF : 1 UDFS: INVALID VAL : 0
Please send the output of:
both when the record type is ai and int64in.
The parameter 293 has the value set correctly. However, PV is 0.
kgofron@HP-Z6-G4$ caget TPX3-TEST:cam1:StartTime_RBV
TPX3-TEST:cam1:StartTime_RBV 0
The behavior is same if I explicitly use 1661466046253LL
setInteger64Param(ADTimePixStartTime,
1661466046253LL);
Behavior is same if I use int64in
epics> asynReport 1 TPX3
TPX3 multiDevice:No canBlock:Yes autoConnect:Yes
enabled:Yes connected:Yes numberConnects 1
nDevices 0 nQueued 0 blocked:No
asynManagerLock:No synchronousLock:No
exceptionActive:No exceptionUsers 1 exceptionNotifys 0
traceMask:0x1 traceIOMask:0x2 traceInfoMask:0x1
2022/08/26 12:41:19.235 ADTimePix::report reporting to external log file
Connected Device Information
Timestamp: 2022/08/26 12:34:48.194
Number of parameters is: 299
Parameter 0 type=string, name=PORT_NAME_SELF, value=TPX3, status=0
Parameter 1 type=string, name=ADCORE_VERSION, value=3.11.0, status=0
Parameter 2 type=string, name=DRIVER_VERSION, value=0.1.0, status=0
Parameter 3 type=string, name=MANUFACTURER, value=ASI, status=0
Parameter 4 type=string, name=MODEL, value=Tpx3, status=0
Parameter 5 type=string, name=SERIAL_NUMBER, value=41000039, status=0
Parameter 6 type=string, name=SDK_VERSION, value=2.3.6, status=0
Parameter 7 type=string, name=FIRMWARE_VERSION, value=18052510, status=0
Parameter 8 type=asynInt32, name=ACQUIRE, value=0, status=0
Parameter 9 type=asynInt32, name=ACQUIRE_BUSY, value=0, status=0
Parameter 10 type=asynInt32, name=WAIT_FOR_PLUGINS, value=0, status=0
Parameter 11 type=asynInt32, name=ARRAY_SIZE_X, value=512, status=0
Parameter 12 type=asynInt32, name=ARRAY_SIZE_Y, value=512, status=0
Parameter 13 type=asynInt32, name=ARRAY_SIZE_Z, value=0, status=0
Parameter 14 type=asynInt32, name=ARRAY_SIZE, value=524288, status=0
Parameter 15 type=asynInt32, name=ARRAY_NDIMENSIONS, value=0, status=0
Parameter 16 type=asynInt32, name=ARRAY_DIMENSIONS, value is undefined
Parameter 17 type=asynInt32, name=DATA_TYPE, value=3, status=0
Parameter 18 type=asynInt32, name=COLOR_MODE, value=0, status=0
Parameter 19 type=asynInt32, name=UNIQUE_ID, value=0, status=0
Parameter 20 type=asynFloat64, name=TIME_STAMP, value=0, status=0
Parameter 21 type=asynInt32, name=EPICS_TS_SEC, value=0, status=0
Parameter 22 type=asynInt32, name=EPICS_TS_NSEC, value=0, status=0
Parameter 23 type=asynInt32, name=BAYER_PATTERN, value=0, status=0
Parameter 24 type=string, name=CODEC, value is undefined
Parameter 25 type=asynInt32, name=COMPRESSED_SIZE, value is undefined
Parameter 26 type=asynInt32, name=ARRAY_COUNTER, value=13, status=0
Parameter 27 type=string, name=FILE_PATH, value=, status=0
Parameter 28 type=asynInt32, name=FILE_PATH_EXISTS, value is undefined
Parameter 29 type=string, name=FILE_NAME, value=, status=0
Parameter 30 type=asynInt32, name=FILE_NUMBER, value=0, status=0
Parameter 31 type=string, name=FILE_TEMPLATE, value=%s%s_%3.3d.dat, status=0
Parameter 32 type=asynInt32, name=AUTO_INCREMENT, value=0, status=0
Parameter 33 type=string, name=FULL_FILE_NAME, value is undefined
Parameter 34 type=asynInt32, name=FILE_FORMAT, value is undefined
Parameter 35 type=asynInt32, name=AUTO_SAVE, value is undefined
Parameter 36 type=asynInt32, name=WRITE_FILE, value=0, status=0
Parameter 37 type=asynInt32, name=READ_FILE, value=0, status=0
Parameter 38 type=asynInt32, name=WRITE_MODE, value is undefined
Parameter 39 type=asynInt32, name=WRITE_STATUS, value=0, status=0
Parameter 40 type=string, name=WRITE_MESSAGE, value=, status=0
Parameter 41 type=asynInt32, name=NUM_CAPTURE, value is undefined
Parameter 42 type=asynInt32, name=NUM_CAPTURED, value=0, status=0
Parameter 43 type=asynInt32, name=CAPTURE, value=0, status=0
Parameter 44 type=asynInt32, name=DELETE_DRIVER_FILE, value is undefined
Parameter 45 type=asynInt32, name=FILE_LAZY_OPEN, value is undefined
Parameter 46 type=asynInt32, name=CREATE_DIR, value=0, status=0
Parameter 47 type=string, name=FILE_TEMP_SUFFIX, value=, status=0
Parameter 48 type=string, name=ND_ATTRIBUTES_FILE, value=, status=0
Parameter 49 type=asynInt32, name=ND_ATTRIBUTES_STATUS, value=1, status=0
Parameter 50 type=string, name=ND_ATTRIBUTES_MACROS, value=, status=0
Parameter 51 is undefined, name=ARRAY_DATA
Parameter 52 type=asynInt32, name=ARRAY_CALLBACKS, value=1, status=0
Parameter 53 type=asynInt32, name=POOL_MAX_BUFFERS, value is undefined
Parameter 54 type=asynInt32, name=POOL_ALLOC_BUFFERS, value=5, status=0
Parameter 55 type=asynInt32, name=POOL_FREE_BUFFERS, value=2, status=0
Parameter 56 type=asynFloat64, name=POOL_MAX_MEMORY, value=0, status=0
Parameter 57 type=asynFloat64, name=POOL_USED_MEMORY, value=2.5, status=0
Parameter 58 type=asynInt32, name=POOL_EMPTY_FREELIST, value is undefined
Parameter 59 type=asynInt32, name=NUM_QUEUED_ARRAYS, value=0, status=0
Parameter 60 type=asynFloat64, name=GAIN, value=1, status=0
Parameter 61 type=asynInt32, name=BIN_X, value=1, status=0
Parameter 62 type=asynInt32, name=BIN_Y, value=1, status=0
Parameter 63 type=asynInt32, name=MIN_X, value=0, status=0
Parameter 64 type=asynInt32, name=MIN_Y, value=0, status=0
Parameter 65 type=asynInt32, name=SIZE_X, value=512, status=0
Parameter 66 type=asynInt32, name=SIZE_Y, value=512, status=0
Parameter 67 type=asynInt32, name=MAX_SIZE_X, value=512, status=0
Parameter 68 type=asynInt32, name=MAX_SIZE_Y, value=512, status=0
Parameter 69 type=asynInt32, name=REVERSE_X, value=0, status=0
Parameter 70 type=asynInt32, name=REVERSE_Y, value=0, status=0
Parameter 71 type=asynInt32, name=FRAME_TYPE, value=0, status=0
Parameter 72 type=asynInt32, name=IMAGE_MODE, value=1, status=0
Parameter 73 type=asynInt32, name=NEXPOSURES, value=1, status=0
Parameter 74 type=asynInt32, name=NEXPOSURES_COUNTER, value=0, status=0
Parameter 75 type=asynInt32, name=NIMAGES, value=10, status=0
Parameter 76 type=asynInt32, name=NIMAGES_COUNTER, value=6, status=0
Parameter 77 type=asynFloat64, name=ACQ_TIME, value=0.1, status=0
Parameter 78 type=asynFloat64, name=ACQ_PERIOD, value=0.2, status=0
Parameter 79 type=asynFloat64, name=TIME_REMAINING, value=0, status=0
Parameter 80 type=asynInt32, name=STATUS, value=0, status=0
Parameter 81 type=asynInt32, name=TRIGGER_MODE, value=4, status=0
Parameter 82 type=asynInt32, name=SHUTTER_CONTROL, value=0, status=0
Parameter 83 type=asynInt32, name=SHUTTER_CONTROL_EPICS, value is undefined
Parameter 84 type=asynInt32, name=SHUTTER_STATUS, value=0, status=0
Parameter 85 type=asynInt32, name=SHUTTER_MODE, value=0, status=0
Parameter 86 type=asynFloat64, name=SHUTTER_OPEN_DELAY, value=0, status=0
Parameter 87 type=asynFloat64, name=SHUTTER_CLOSE_DELAY, value=0, status=0
Parameter 88 type=asynFloat64, name=TEMPERATURE, value=25, status=0
Parameter 89 type=asynFloat64, name=TEMPERATURE_ACTUAL, value is undefined
Parameter 90 type=asynInt32, name=READ_STATUS, value is undefined
Parameter 91 type=string, name=STATUS_MESSAGE, value=, status=0
Parameter 92 type=string, name=STRING_TO_SERVER, value=, status=0
Parameter 93 type=string, name=STRING_FROM_SERVER, value=, status=0
Parameter 94 type=string, name=TPX3_FW_TIMESTAMP, value=2022/01/05 11:07, status=0
Parameter 95 type=string, name=TPX3_DETECTOR_TYPE, value=Tpx3, status=0
Parameter 96 type=asynInt32, name=TPX3_HTTP_CODE, value=200, status=0
Parameter 98 type=asynFloat64, name=TPX3_LOCAL_TEMP, value=40, status=0
Parameter 99 type=asynFloat64, name=TPX3_FPGA_TEMP, value=40, status=0
Parameter 100 type=asynFloat64, name=TPX3_FAN1_SPEED, value=0, status=0
Parameter 101 type=asynFloat64, name=TPX3_FAN2_SPEED, value=0, status=0
Parameter 102 type=asynFloat64, name=TPX3_BIAS_VOLT_H, value=11.9751, status=0
Parameter 103 type=string, name=TPX3_CHIP_TEMPS, value=[11,89,89,89], status=0
Parameter 104 type=string, name=TPX3_VDD, value=[1.5,0.0004,0.6], status=0
Parameter 105 type=string, name=TPX3_AVDD, value=[1.5,0.0004,0.6], status=0
Parameter 106 type=asynInt32, name=TPX3_HEALTH, value=0, status=0
Parameter 107 type=string, name=TPX3_IFACE, value=Spidr, status=0
Parameter 108 type=string, name=TPX3_CHIPID, value=41000039, status=0
Parameter 109 type=string, name=TPX3_SW_VER, value=19081915, status=0
Parameter 110 type=string, name=TPX3_FW_VER, value=18052510, status=0
Parameter 111 type=asynInt32, name=TPX3_PEL_CNT, value=262144, status=0
Parameter 112 type=asynInt32, name=TPX3_ROWLEN, value=2, status=0
Parameter 113 type=asynInt32, name=TPX3_NUM_CHIPS, value=4, status=0
Parameter 114 type=asynInt32, name=TPX3_NUM_ROWS, value=512, status=0
Parameter 115 type=asynInt32, name=TPX3_MPX_TYPE, value=6, status=0
Parameter 116 type=string, name=TPX3_BOARDS_ID, value=41000039, status=0
Parameter 117 type=string, name=TPX3_BOARDS_IP, value=127.0.0.10, status=0
Parameter 118 type=asynInt32, name=TPX3_BOARDS_PORT, value=8192, status=0
Parameter 119 type=string, name=TPX3_BOARDS_CH1, value="Id":680,"Name":"W0002_H10", status=0
Parameter 120 type=string, name=TPX3_BOARDS_CH2, value="Id":681,"Name":"W0002_I10", status=0
Parameter 121 type=string, name=TPX3_BOARDS_CH3, value="Id":682,"Name":"W0002_J10", status=0
Parameter 122 type=string, name=TPX3_BOARDS_CH4, value="Id":683,"Name":"W0002_K10", status=0
Parameter 123 type=asynInt32, name=TPX3_ACQ_MODES, value=63, status=0
Parameter 124 type=asynFloat64, name=TPX3_CLOCK_READ, value=125, status=0
Parameter 125 type=asynInt32, name=TPX3_PULSE_CNT, value=2147483647, status=0
Parameter 126 type=asynFloat64, name=TPX3_PULSE_HIGHT, value=1, status=0
Parameter 127 type=asynFloat64, name=TPX3_PULSE_PERIOD, value=34.3597, status=0
Parameter 128 type=asynFloat64, name=TPX3_TIME_MAX, value=34.3597, status=0
Parameter 129 type=asynFloat64, name=TPX3_TIME_MIN, value=8e-09, status=0
Parameter 130 type=asynFloat64, name=TPX3_TIME_STEP, value=8e-09, status=0
Parameter 131 type=asynFloat64, name=TPX3_CLOCK, value=125, status=0
Parameter 132 type=asynInt32, name=TPX3_FAN1PWM, value=0, status=0
Parameter 133 type=asynInt32, name=TPX3_FAN2PWM, value=0, status=0
Parameter 134 type=asynInt32, name=TPX3_BIAS_VOLT_R, value=12, status=0
Parameter 135 type=asynInt32, name=TPX3_BIAS_ENBL, value=1, status=0
Parameter 136 type=string, name=TPX3_CHAIN_MODE, value=NONE, status=0
Parameter 137 type=asynInt32, name=TPX3_TRIGGER_IN, value=0, status=0
Parameter 138 type=asynInt32, name=TPX3_TRIGGER_OUT, value=0, status=0
Parameter 139 type=string, name=TPX3_POLARITY, value=Positive, status=0
Parameter 140 type=string, name=TPX3_TRIGGER_MODE, value=AUTOTRIGSTART_TIMERSTOP, status=0
Parameter 141 type=asynFloat64, name=TPX3_EXPOSURE_TIME, value=0.1, status=0
Parameter 142 type=asynFloat64, name=TPX3_TRIGGER_PERIOD, value=0.2, status=0
Parameter 143 type=asynInt32, name=TPX3_NTRIGGERS, value=10, status=0
Parameter 144 type=string, name=TPX3_DET_ORIENTATION, value=UP, status=0
Parameter 145 type=asynInt32, name=TPX3_PERIPH_CLK80, value=0, status=0
Parameter 146 type=asynFloat64, name=TPX3_TRIG_DELAY, value=0, status=0
Parameter 147 type=string, name=TPX3_TDC, value="PN0123","PN0123", status=0
Parameter 148 type=asynFloat64, name=TPX3_GL_TIMESTAMP_INT, value=0, status=0
Parameter 149 type=asynInt32, name=TPX3_EXT_REF_CLOCK, value=0, status=0
Parameter 150 type=asynInt32, name=TPX3_LOG_LEVEL, value=1, status=0
Parameter 151 type=asynInt32, name=TPX3_CHIP0_CP_PLL, value=128, status=0
Parameter 152 type=asynInt32, name=TPX3_CHIP0_DISCS1OFF, value=8, status=0
Parameter 153 type=asynInt32, name=TPX3_CHIP0_DISCS1ON, value=128, status=0
Parameter 154 type=asynInt32, name=TPX3_CHIP0_DISCS2OFF, value=8, status=0
Parameter 155 type=asynInt32, name=TPX3_CHIP0_DISCS2ON, value=128, status=0
Parameter 156 type=asynInt32, name=TPX3_CHIP0_IKRUM, value=10, status=0
Parameter 157 type=asynInt32, name=TPX3_CHIP0_PIXELDAC, value=230, status=0
Parameter 158 type=asynInt32, name=TPX3_CHIP0_PREAMPOFF, value=8, status=0
Parameter 159 type=asynInt32, name=TPX3_CHIP0_PREAMPON, value=128, status=0
Parameter 160 type=asynInt32, name=TPX3_CHIP0_TPBUFFERIN, value=128, status=0
Parameter 161 type=asynInt32, name=TPX3_CHIP0_TPBUFFEROUT, value=128, status=0
Parameter 162 type=asynInt32, name=TPX3_CHIP0_PLL_VCNTRL, value=128, status=0
Parameter 163 type=asynInt32, name=TPX3_CHIP0_VPREAMPNCAS, value=128, status=0
Parameter 164 type=asynInt32, name=TPX3_CHIP0_VTP_COARSE, value=128, status=0
Parameter 165 type=asynInt32, name=TPX3_CHIP0_VTP_FINE, value=256, status=0
Parameter 166 type=asynInt32, name=TPX3_CHIP0_VFBK, value=128, status=0
Parameter 167 type=asynInt32, name=TPX3_CHIP0_VTH_COARSE, value=6, status=0
Parameter 168 type=asynInt32, name=TPX3_CHIP0_VTH_FINE, value=216, status=0
Parameter 169 type=string, name=TPX3_CHIP0_ADJUST, value is undefined
Parameter 170 type=asynInt32, name=TPX3_CHIP1_CP_PLL, value=128, status=0
Parameter 171 type=asynInt32, name=TPX3_CHIP1_DISCS1OFF, value=8, status=0
Parameter 172 type=asynInt32, name=TPX3_CHIP1_DISCS1ON, value=128, status=0
Parameter 173 type=asynInt32, name=TPX3_CHIP1_DISCS2OFF, value=8, status=0
Parameter 174 type=asynInt32, name=TPX3_CHIP1_DISCS2ON, value=128, status=0
Parameter 175 type=asynInt32, name=TPX3_CHIP1_IKRUM, value=10, status=0
Parameter 176 type=asynInt32, name=TPX3_CHIP1_PIXELDAC, value=247, status=0
Parameter 177 type=asynInt32, name=TPX3_CHIP1_PREAMPOFF, value=8, status=0
Parameter 178 type=asynInt32, name=TPX3_CHIP1_PREAMPON, value=128, status=0
Parameter 179 type=asynInt32, name=TPX3_CHIP1_TPBUFFERIN, value=128, status=0
Parameter 180 type=asynInt32, name=TPX3_CHIP1_TPBUFFEROUT, value=128, status=0
Parameter 181 type=asynInt32, name=TPX3_CHIP1_PLL_VCNTRL, value=128, status=0
Parameter 182 type=asynInt32, name=TPX3_CHIP1_VPREAMPNCAS, value=128, status=0
Parameter 183 type=asynInt32, name=TPX3_CHIP1_VTP_COARSE, value=128, status=0
Parameter 184 type=asynInt32, name=TPX3_CHIP1_VTP_FINE, value=256, status=0
Parameter 185 type=asynInt32, name=TPX3_CHIP1_VFBK, value=128, status=0
Parameter 186 type=asynInt32, name=TPX3_CHIP1_VTH_COARSE, value=6, status=0
Parameter 187 type=asynInt32, name=TPX3_CHIP1_VTH_FINE, value=253, status=0
Parameter 188 type=string, name=TPX3_CHIP1_ADJUST, value is undefined
Parameter 189 type=asynInt32, name=TPX3_CHIP2_CP_PLL, value=128, status=0
Parameter 190 type=asynInt32, name=TPX3_CHIP2_DISCS1OFF, value=8, status=0
Parameter 191 type=asynInt32, name=TPX3_CHIP2_DISCS1ON, value=128, status=0
Parameter 192 type=asynInt32, name=TPX3_CHIP2_DISCS2OFF, value=8, status=0
Parameter 193 type=asynInt32, name=TPX3_CHIP2_DISCS2ON, value=128, status=0
Parameter 194 type=asynInt32, name=TPX3_CHIP2_IKRUM, value=10, status=0
Parameter 195 type=asynInt32, name=TPX3_CHIP2_PIXELDAC, value=251, status=0
Parameter 196 type=asynInt32, name=TPX3_CHIP2_PREAMPOFF, value=8, status=0
Parameter 197 type=asynInt32, name=TPX3_CHIP2_PREAMPON, value=128, status=0
Parameter 198 type=asynInt32, name=TPX3_CHIP2_TPBUFFERIN, value=128, status=0
Parameter 199 type=asynInt32, name=TPX3_CHIP2_TPBUFFEROUT, value=128, status=0
Parameter 200 type=asynInt32, name=TPX3_CHIP2_PLL_VCNTRL, value=128, status=0
Parameter 201 type=asynInt32, name=TPX3_CHIP2_VPREAMPNCAS, value=128, status=0
Parameter 202 type=asynInt32, name=TPX3_CHIP2_VTP_COARSE, value=128, status=0
Parameter 203 type=asynInt32, name=TPX3_CHIP2_VTP_FINE, value=256, status=0
Parameter 204 type=asynInt32, name=TPX3_CHIP2_VFBK, value=128, status=0
Parameter 205 type=asynInt32, name=TPX3_CHIP2_VTH_COARSE, value=6, status=0
Parameter 206 type=asynInt32, name=TPX3_CHIP2_VTH_FINE, value=221, status=0
Parameter 207 type=string, name=TPX3_CHIP2_ADJUST, value is undefined
Parameter 208 type=asynInt32, name=TPX3_CHIP3_CP_PLL, value=128, status=0
Parameter 209 type=asynInt32, name=TPX3_CHIP3_DISCS1OFF, value=8, status=0
Parameter 210 type=asynInt32, name=TPX3_CHIP3_DISCS1ON, value=128, status=0
Parameter 211 type=asynInt32, name=TPX3_CHIP3_DISCS2OFF, value=8, status=0
Parameter 212 type=asynInt32, name=TPX3_CHIP3_DISCS2ON, value=128, status=0
Parameter 213 type=asynInt32, name=TPX3_CHIP3_IKRUM, value=10, status=0
Parameter 214 type=asynInt32, name=TPX3_CHIP3_PIXELDAC, value=215, status=0
Parameter 215 type=asynInt32, name=TPX3_CHIP3_PREAMPOFF, value=8, status=0
Parameter 216 type=asynInt32, name=TPX3_CHIP3_PREAMPON, value=128, status=0
Parameter 217 type=asynInt32, name=TPX3_CHIP3_TPBUFFERIN, value=128, status=0
Parameter 218 type=asynInt32, name=TPX3_CHIP3_TPBUFFEROUT, value=128, status=0
Parameter 219 type=asynInt32, name=TPX3_CHIP3_PLL_VCNTRL, value=128, status=0
Parameter 220 type=asynInt32, name=TPX3_CHIP3_VPREAMPNCAS, value=128, status=0
Parameter 221 type=asynInt32, name=TPX3_CHIP3_VTP_COARSE, value=128, status=0
Parameter 222 type=asynInt32, name=TPX3_CHIP3_VTP_FINE, value=256, status=0
Parameter 223 type=asynInt32, name=TPX3_CHIP3_VFBK, value=128, status=0
Parameter 224 type=asynInt32, name=TPX3_CHIP3_VTH_COARSE, value=6, status=0
Parameter 225 type=asynInt32, name=TPX3_CHIP3_VTH_FINE, value=210, status=0
Parameter 226 type=string, name=TPX3_CHIP3_ADJUST, value is undefined
Parameter 227 type=string, name=TPX3_CHIP0_LAYTOUT, value={"Orientation":"LtRBtT","X":1,"Y":0}, status=0
Parameter 228 type=string, name=TPX3_CHIP1_LAYTOUT, value={"Orientation":"RtLTtB","X":1,"Y":1}, status=0
Parameter 229 type=string, name=TPX3_CHIP2_LAYTOUT, value={"Orientation":"RtLTtB","X":0,"Y":1}, status=0
Parameter 230 type=string, name=TPX3_CHIP3_LAYTOUT, value={"Orientation":"LtRBtT","X":0,"Y":0}, status=0
Parameter 231 type=string, name=BPC_FILE_PATH, value=, status=0
Parameter 232 type=asynInt32, name=BPC_FILE_PATH_EXISTS, value is undefined
Parameter 233 type=string, name=BPC_FILE_NAME, value=, status=0
Parameter 234 type=string, name=DACS_FILE_PATH, value=, status=0
Parameter 235 type=asynInt32, name=DACS_FILE_PATH_EXISTS, value is undefined
Parameter 236 type=string, name=DACS_FILE_NAME, value=, status=0
Parameter 237 type=string, name=WRITE_FILE_MESSAGE, value=Successfully uploaded destination configuration.
Parameter 238 type=asynInt32, name=WRITE_BPC_FILE, value is undefined
Parameter 239 type=asynInt32, name=WRITE_DACS_FILE, value is undefined
Parameter 240 type=asynInt32, name=TPX3_WRITE_DATA, value=1, status=0
Parameter 241 type=asynInt32, name=TPX3_WRITE_RAW, value=1, status=0
Parameter 242 type=asynInt32, name=TPX3_WRITE_IMG, value=1, status=0
Parameter 243 type=asynInt32, name=TPX3_WRITE_PRVIMG, value=1, status=0
Parameter 244 type=asynInt32, name=TPX3_WRITE_PRVIMG1, value=1, status=0
Parameter 245 type=asynInt32, name=TPX3_WRITE_PRVHST, value=0, status=0
Parameter 246 type=string, name=TPX3_RAW_BASE, value=/media/nvme/raw/, status=0
Parameter 247 type=string, name=TPX3_RAW_FILEPAT, value=raw%Hms_, status=0
Parameter 248 type=asynInt32, name=TPX3_RAW_SPLITSTG, value=0, status=0
Parameter 249 type=asynInt32, name=TPX3_RAW_QUEUESIZE, value=16384, status=0
Parameter 250 type=asynInt32, name=RAW_FILE_PATH_EXISTS, value=1, status=0
Parameter 251 type=string, name=TPX3_IMG_IMGBASE, value=/media/nvme/img/, status=0
Parameter 252 type=string, name=TPX3_IMG_IMGPAT, value=f%Hms_, status=0
Parameter 253 type=asynInt32, name=TPX3_IMG_IMGFORMAT, value=0, status=0
Parameter 254 type=asynInt32, name=TPX3_IMG_IMGMODE, value=1, status=0
Parameter 255 type=string, name=TPX3_IMG_IMGTHS, value is undefined
Parameter 256 type=asynInt32, name=TPX3_IMG_INTSIZE, value=1, status=0
Parameter 257 type=asynInt32, name=TPX3_IMG_INTMODE, value is undefined
Parameter 258 type=asynInt32, name=TPX3_IMG_STPONDSK, value=1, status=0
Parameter 259 type=asynInt32, name=TPX3_IMG_QUEUESIZE, value=1024, status=0
Parameter 260 type=asynInt32, name=IMG_FILE_PATH_EXISTS, value=1, status=0
Parameter 261 type=asynFloat64, name=TPX3_PRV_PERIOD, value=0.2, status=0
Parameter 262 type=asynInt32, name=TPX3_PRV_SAMPLMODE, value=0, status=0
Parameter 263 type=string, name=TPX3_PRV_IMGBASE, value=/media/nvme/prv/, status=0
Parameter 264 type=string, name=TPX3_PRV_IMGPAT, value=f%Hms_, status=0
Parameter 265 type=asynInt32, name=TPX3_PRV_IMGFORMAT, value=2, status=0
Parameter 266 type=asynInt32, name=TPX3_PRV_IMGMODE, value=1, status=0
Parameter 267 type=string, name=TPX3_PRV_IMGTHS, value is undefined
Parameter 268 type=asynInt32, name=TPX3_PRV_INTSIZE, value=1, status=0
Parameter 269 type=asynInt32, name=TPX3_PRV_INTMODE, value=1, status=0
Parameter 270 type=asynInt32, name=TPX3_PRV_STPONDSK, value=0, status=0
Parameter 271 type=asynInt32, name=TPX3_PRV_QUEUESIZE, value=16, status=0
Parameter 272 type=asynInt32, name=PRV_IMG_FILE_PATH_EXISTS, value=1, status=0
Parameter 273 type=string, name=TPX3_PRV_IMG1BASE, value=http://localhost,
status=0
Parameter 274 type=asynInt32, name=TPX3_PRV_IMG1FORMAT, value=0, status=0
Parameter 275 type=asynInt32, name=TPX3_PRV_IMG1MODE, value=1, status=0
Parameter 276 type=string, name=TPX3_PRV_IMG1THS, value is undefined
Parameter 277 type=asynInt32, name=TPX3_PRV_IMG1INTSIZE, value=1, status=0
Parameter 278 type=asynInt32, name=TPX3_PRV_IMG1INTMODE, value=1, status=0
Parameter 279 type=asynInt32, name=TPX3_PRV_IMG1STPONDSK, value=0, status=0
Parameter 280 type=asynInt32, name=TPX3_PRV_IMG1QUEUESIZE, value=16, status=0
Parameter 281 type=string, name=TPX3_PRV_HSTBASE, value=/media/nvme/hst/, status=0
Parameter 282 type=string, name=TPX3_PRV_HSTPAT, value=f%Hms_, status=0
Parameter 283 type=asynInt32, name=TPX3_PRV_HSTFORMAT, value=4, status=0
Parameter 284 type=asynInt32, name=TPX3_PRV_HSTMODE, value=1, status=0
Parameter 285 type=string, name=TPX3_PRV_HSTTHS, value is undefined
Parameter 286 type=asynInt32, name=TPX3_PRV_HSTINTSIZE, value=1, status=0
Parameter 287 type=asynInt32, name=TPX3_PRV_HSTINTMODE, value=1, status=0
Parameter 288 type=asynInt32, name=TPX3_PRV_HSTSTPONDSK, value=0, status=0
Parameter 289 type=asynInt32, name=TPX3_PRV_HSTQUEUESIZE, value=16, status=0
Parameter 290 type=asynInt32, name=PRV_HST_FILE_PATH_EXISTS, value=1, status=0
Parameter 291 type=asynInt32, name=TPX3_PEL_RATE, value=67582870, status=0
Parameter 292 type=asynInt32, name=TPX3_TDC_RATE, value=0, status=0
Parameter 294 type=asynFloat64, name=TPX3_ELAPSED_TIME, value=3.018, status=0
Parameter 295 type=asynFloat64, name=TPX3_TIME_LEFT, value=0.8, status=0
Parameter 296 type=asynInt32, name=TPX3_FRAME_COUNT, value=6, status=0
Parameter 297 type=asynInt32, name=TPX3_DROPPED_FRAMES, value=4, status=0
Parameter 298 type=string, name=TPX3_MSMT_STATUS, value="DA_IDLE", status=0
NDArray Array address=0x7f036c083530:
dataType=3, dataSize=524288, pData=0x7f036c083760
uniqueId=6, timeStamp=1030379687.975780, epicsTS.secPastEpoch=1030379688, epicsTS.nsec=194276556
>>I wonder if "ai" record is correct for asyInt64.
> Of course not ;-)
Actually the ai record works with asynInt64, and is documented here:
A 64-bit integer is read from the driver and converted to a 64-bit float. The 64-bit float can exactly represent integers up to 52 bits. The value is read into the .VAL field, not the .RVAL field.
Linear conversion is limited to .EOFF and .ESLO. Each time the record is processed a new value is read. SCAN "I/O Intr" is supported.
Even if it does not do what Kaz wants because of the limited number of bits, it should not giving a 0 value.
Perhaps this problem is this line:
setInteger64Param(ADTimePixStartTime, 1661466046253);
setInteger64Param(ADTimePixStartTime, 1661466046253LL);
i.e. explicitly tell the compiler that is a long long constant.
If that does not work then please send the output of
That will show the values of all parameters in the parameter library, and we can see if it has the correct value there.
Hej Kaz
Of course not ;-)
Please try
field(DTYP, "asynInt64")
field(SCAN, "I/O Intr")
/Torsten
Sorry, I copied a wrong record to the previous email.
1661466046253);
createParam(ADTimePixStartTimeString,
asynParamInt64, &ADTimePixStartTime);
The callParamCallbacks(); was
there. I added additional one just after the setInteger64Param()
I just noticed that you created the parameter with Type asynInt64 but your record has DTYP asynFloat64. That is not correct, and should have produced an error
message after iocInit.
You should either use an ai record with DTYP asynInt64 or an int64In record.
I am writing an areaDetector driver that reads integer time in multiples of fractions of ns.
record(ai, "$(P)$(R)ElapsedTime_RBV"){
field(DTYP, "asynFloat64")
field(INP, "@asyn($(PORT),$(ADDR),$(TIMEOUT))TPX3_ELAPSED_TIME")
In the driver the value is set using (hard coded value here):
However, the PV value does not change from 0.
The caput changes the value of PV:
kgofron@myHP$ caput TPX3-TEST:cam1:StartTime_RBV 1661466046253
Old : TPX3-TEST:cam1:StartTime_RBV 0
New : TPX3-TEST:cam1:StartTime_RBV 1.66147e+12
Any suggestions would be much appreciated.
