1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: how to use the GUN-RC-300 in mrfioc2
From: Michael Davidsaver via Tech-talk <tech-talk at aps.anl.gov>
To: 문건영(선형가속기팀) <gymun at postech.ac.kr>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Mon, 12 Jun 2023 08:43:11 -0700
On 6/5/23 00:55, 문건영(선형가속기팀) via Tech-talk wrote:
Dear All,
I'm trying to operate the GUN-RC-300 on MTCA-EVR-300RF.
Firstly a disclaimer.  I have no experience with this specific model.
(I am not even sure that I had heard of it before)
MRF has made several different boards which all reuse the same
MTCA-EVR-300 PCI ID.  Software, and some engineers, find this
difficult to distinguish.  The board you have may or may not be the
same "RF mTCA EVR" mentioned in this PR.
https://github.com/epics-modules/mrfioc2/pull/63
I made the mtca-evr-300rf.substitutions file as below by referring to file evr-tg-300.substitutions.
Fill in only the information related to gun-rc-300.
file "mrmevrout.db"
{pattern
{ON, OBJ, DESC}
{"$(SYS){$(D)-Out:Int}", "$(EVR):Int", "Internal"}
{"$(SYS){$(D)-Out:FP0}", "$(EVR):FrontOut0", "OUT0 (GTX)"}
{"$(SYS){$(D)-Out:FP1}", "$(EVR):FrontOut1", "OUT1 (GTX)"}
{"$(SYS){$(D)-Out:FP2}", "$(EVR):FrontOut2", "OUT2 (GTX)"}
{"$(SYS){$(D)-Out:FP3}", "$(EVR):FrontOut3", "OUT3 (GTX)"}
{"$(SYS){$(D)-Out:FPUV0}", "$(EVR):FrontUnivOut0", "FPUV0 (TTL)"}
{"$(SYS){$(D)-Out:FPUV1}", "$(EVR):FrontUnivOut1", "FPUV1 (TTL)"}
{"$(SYS){$(D)-Out:FPUV2}", "$(EVR):FrontUnivOut2", "FPUV2 (GTX)"}
{"$(SYS){$(D)-Out:FPUV3}", "$(EVR):FrontUnivOut3", "FPUV3 (GTX)"}
file "evrcml.db"
{pattern
{P, ON, OBJ}
{"$(SYS){$(D)}", "$(SYS){$(D)-Out:FP0}", "$(EVR):CML0"}
{"$(SYS){$(D)}", "$(SYS){$(D)-Out:FP1}", "$(EVR):CML1"}
{"$(SYS){$(D)}", "$(SYS){$(D)-Out:FP2}", "$(EVR):CML2"}
{"$(SYS){$(D)}", "$(SYS){$(D)-Out:FP3}", "$(EVR):CML3"}
{"$(SYS){$(D)}", "$(SYS){$(D)-Out:FPUV2}", "$(EVR):CML4"}
{"$(SYS){$(D)}", "$(SYS){$(D)-Out:FPUV3}", "$(EVR):CML5"}
file "evrcmlgun.db"
{pattern
{ON, OBJ}
{"$(SYS){$(D)-Out:FP0}", "$(EVR):CML0"}
{"$(SYS){$(D)-Out:FP1}", "$(EVR):CML1"}
{"$(SYS){$(D)-Out:FP2}", "$(EVR):CML2"}
{"$(SYS){$(D)-Out:FP3}", "$(EVR):CML3"}
When evr IOC is running, the "RX ON" indicator is ON in the GUN-RC-300.
But, "PULSE" indicator is not working. I don't know how to use it in CSS opi.
Or I'm not sure mtca-evr-300rf.substitutions file setting.
If anyone knows anything about this, I'd appreciate your help.
The latest version of the MRF manuals which I have (2021 October) has section
"3.1.13. mTCA-EVR-300RF".
The mTCA-EVR-300RF has altogether six GTX outputs, two on the backplane,
TCLKA and TCLKB, and four on the front panel: one Universal I/O slot
(UNIV2/UNIV3), one SFP output, and one differential CML output.
As I read this, the SFP output would be the 5th GTX/CML output (index 4).
The following paragraph is:
The GUN-TX mode has a special inhibit function that by default is using
Universal Input 0 as an inhibit signal. When the state of the inhibit
signal is high the GUN-TX output is disabled. The inhibit function may be
overridden with the GTXIO override bit in the main control register.
To bypass while testing, look for the "External Inhibit" property in evrbase.db
Additionally, the relevant GTX output may need to be set to one of the SFP
output modes.  Probably "GUN-TX-300 Mode".  This currently can't be done
from a DB file, but only from code.  I think PR 63 does this.
If you are able to get this working, please comment on PR 63 or let me know
through some other medium.
how to use the GUN-RC-300 in mrfioc2 문건영(선형가속기팀) via Tech-talk
Prev: Re: Optional record alias Ralph Lange via Tech-talk
Next: add fields to an existing record Wolfman, Mark via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Prev: how to use the GUN-RC-300 in mrfioc2 문건영(선형가속기팀) via Tech-talk
Next: Job Opportunity at BESSY II Smith, William via Tech-talk
ANJ, 12 Jun 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
