Hello,
Has anyone had any luck installing EPICS on CentOS 7? Of the required packages for CentOS 8, I can install all but one (gcc-toolset-8-make) and there is no powertools for config-manager. It throws some errors but ultimately looks like it installs, but the basic tutorial does not work. When I try to "caget temperature:water", it responds with "Channel connect timed out: 'temperature:water' not found.". I'm guessing this is because it isn't installed correctly. Is it possible that the install is okay and there is a configuration issue preventing the caget from talking to the EPICS server? Thank you, Brandon
ANJ, 15 Jun 2023 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
