1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: Issue installing asyn on CentOS 7
From: Torsten Bögershausen via Tech-talk <tech-talk at aps.anl.gov>
To: Brandon Gunn <bgunn at ucsd.edu>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 15 Jun 2023 06:42:05 +0000
Hm,
which version of asyn are you using ?
In my version of asyn (the latest, kind of) we see in
asyn/asyn/Makefile
ifeq ($(TIRPC),YES)
  USR_INCLUDES_Linux += -I/usr/include/tirpc
  asyn_SYS_LIBS_Linux += tirpc
endif
Do you have the same lines ?
Otherwise just comment out the if/endif and see what happens:
#ifeq ($(TIRPC),YES)
#endif
HTH
/Torsten
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Brandon Gunn via Tech-talk <tech-talk at aps.anl.gov>
Reply to: Brandon Gunn <bgunn at ucsd.edu>
Date: Thursday, 15 June 2023 at 00:20
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Subject: Issue installing asyn on CentOS 7
Hello,
I have encountered another issue while trying to get EPICS installed on our CentOS 7 machine.
Based on similar posts in the mailing list, it seems to be TIRCP related. Here is the error I get when I try to make:
$ make
make -C ./configure install
make[1]: Entering directory `/home/specadm/EPICS/support/asyn/configure'
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[2]: Entering directory `/home/specadm/EPICS/support/asyn/configure/O.linux-x86_64'
perl -CSD /home/specadm/EPICS/epics-base/bin/linux-x86_64/convertRelease.pl checkRelease
make[2]: Leaving directory `/home/specadm/EPICS/support/asyn/configure/O.linux-x86_64'
make[1]: Leaving directory `/home/specadm/EPICS/support/asyn/configure'
make -C ./makeSupport install
make[1]: Entering directory `/home/specadm/EPICS/support/asyn/makeSupport'
make[2]: Entering directory `/home/specadm/EPICS/support/asyn/makeSupport/O.linux-x86_64'
make[2]: Nothing to be done for `install'.
make[2]: Leaving directory `/home/specadm/EPICS/support/asyn/makeSupport/O.linux-x86_64'
make[1]: Leaving directory `/home/specadm/EPICS/support/asyn/makeSupport'
make -C ./opi install
make[1]: Entering directory `/home/specadm/EPICS/support/asyn/opi'
make[1]: Nothing to be done for `install'.
make[1]: Leaving directory `/home/specadm/EPICS/support/asyn/opi'
make -C ./asyn install
make[1]: Entering directory `/home/specadm/EPICS/support/asyn/asyn'
make[2]: Entering directory `/home/specadm/EPICS/support/asyn/asyn/O.linux-x86_64'
make[2]: Leaving directory `/home/specadm/EPICS/support/asyn/asyn/O.linux-x86_64'
make[1]: Leaving directory `/home/specadm/EPICS/support/asyn/asyn'
make -C asyn/asynPortDriver/unittest install
make[1]: Entering directory `/home/specadm/EPICS/support/asyn/asyn/asynPortDriver/unittest'
make -C O.linux-x86_64 -f ../Makefile TOP=../../../.. \
make[2]: Entering directory `/home/specadm/EPICS/support/asyn/asyn/asynPortDriver/unittest/O.linux-x86_64'
/usr/bin/g++ -o asynPortDriverTest  -L/home/specadm/EPICS/support/asyn/lib/linux-x86_64 -L/home/specadm/EPICS/epics-base/lib/linux-x86_64 -Wl,-rpath,/home/specadm/EPICS/support/asyn/lib/linux-x86_64 -Wl,-rpath,/home/specadm/EPICS/epics-base/lib/linux-x86_64           -rdynamic -m64         asynPortDriverTest.o    -lasyn -ldbRecStd -ldbCore -lca -lCom
/home/specadm/EPICS/support/asyn/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_bytes'
/home/specadm/EPICS/support/asyn/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_free'
/home/specadm/EPICS/support/asyn/lib/linux-x86_64/libasyn.so: undefined reference to `clnt_sperror'
/home/specadm/EPICS/support/asyn/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_bool'
/home/specadm/EPICS/support/asyn/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_int'
/home/specadm/EPICS/support/asyn/lib/linux-x86_64/libasyn.so: undefined reference to `clnt_spcreateerror'
/home/specadm/EPICS/support/asyn/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_string'
/home/specadm/EPICS/support/asyn/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_void'
/home/specadm/EPICS/support/asyn/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_enum'
/home/specadm/EPICS/support/asyn/lib/linux-x86_64/libasyn.so: undefined reference to `clnttcp_create'
/home/specadm/EPICS/support/asyn/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_u_char'
/home/specadm/EPICS/support/asyn/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_u_int'
/home/specadm/EPICS/support/asyn/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_u_short'
/home/specadm/EPICS/support/asyn/lib/linux-x86_64/libasyn.so: undefined reference to `xdr_char'
collect2: error: ld returned 1 exit status
make[2]: *** [asynPortDriverTest] Error 1
make[2]: Leaving directory `/home/specadm/EPICS/support/asyn/asyn/asynPortDriver/unittest/O.linux-x86_64'
make[1]: *** [install.linux-x86_64] Error 2
make[1]: Leaving directory `/home/specadm/EPICS/support/asyn/asyn/asynPortDriver/unittest'
make: *** [asyn/asynPortDriver/unittest.install] Error 2
Things I have tried:
1) In configure/CONFIG_SITE, I uncommented the line:
TIRPC=YES
2) In asyn/Makefile, I appended this to the very end:
 ifeq ($(TIRPC),YES)
  endif
3) I removed the empty header files from /usr/include/rpc and replaced them with symbolic links pointing at  the files in /usr/include/tirpc/rpc
Unfortunately, nothing seems to have any effect on the error generated from make and that seems to have exhausted all solutions I could find in the archives. Any ideas about how to fix this?
P.S.: This machine controls our diffractometer and we are just trying to get spec to talk to our Lakeshore 336  -- both asyn and StreamDevice are necessary for this purpose?
Thank you,
Brandon
Re: Issue installing asyn on CentOS 7 Han Lee via Tech-talk
Issue installing asyn on CentOS 7 Brandon Gunn via Tech-talk
Prev: Re: LabCA for MATLAB Installation error Straumann Till Sascha via Tech-talk
Next: Re: Issue installing asyn on CentOS 7 Han Lee via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Prev: Issue installing asyn on CentOS 7 Brandon Gunn via Tech-talk
ANJ, 15 Jun 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
