Hi Mark,
I do actually have these definitions:
CROSS_COMPILER_TARGET_ARCHS=linux-arm_raspberrypi2
linux-arm_raspberrypi3 linux-arm_raspberrypi4
linux-arm_terasicsoc
linux-arm_achilles linux-x86_64cross linux-x86_i486
linux-ppc_mvme8100
and
CROSS_COMPILER_HOST_ARCHS=linux-x86_64
As mentioned before, if I have CROSS_COMPILER_TARGET_ARCHS
empty, then
there is no problem building for the host.
Thank you,
Pierrick
On 6/15/23 10:16, Mark Rivers wrote:
> Hi Pierrick,
> I am cross-compiling with base 7.0.7 (actually master
on May 18) and it works fine for me cross-compiling for
vxWorks-ppc32. I just made these changes to
configure/CONFIG_SITE:
> diff --git a/configure/CONFIG_SITE
b/configure/CONFIG_SITE
> index 03ec6d1..12f5ab1 100644
> --- a/configure/CONFIG_SITE
> +++ b/configure/CONFIG_SITE
> @@ -96,14 +96,14 @@
> # Which target architectures to cross-compile for.
> # Definitions in
configure/os/CONFIG_SITE.<host>.Common
> # may override this setting.
> -CROSS_COMPILER_TARGET_ARCHS=
> +CROSS_COMPILER_TARGET_ARCHS=vxWorks-ppc32
> # If only some of your host architectures can
compile the
> # above CROSS_COMPILER_TARGET_ARCHS specify those
host
> # architectures here. If the combination is
complicated,
> # set CROSS_COMPILER_TARGET_ARCHS in the
appropriate
> # configure/os/CONFIG_SITE.<host>.Common
files instead.
> -CROSS_COMPILER_HOST_ARCHS=
> +CROSS_COMPILER_HOST_ARCHS=linux-x86_64
> # The 'runtests', 'tapfiles' and 'junitfiles' make
targets normally only run
> # self-tests for the EPICS_HOST_ARCH architecture.
If the host can execute
> Mark
> -----Original Message-----
> From: Tech-talk
<tech-talk-bounces at aps.anl.gov>
On Behalf Of Pierrick M Hanlet via Tech-talk
> Sent: Thursday, June 15, 2023 6:08 AM
> To:
tech-talk at aps.anl.gov
> Subject: cross-compiling v7.0.7
> Greetings all,
> Something broke, or I missed new instructions in
building the modules in
> v7.0.7 for cross-compiled platforms.
> I'm building for several platforms. The host build
is fine, but when the cross-compiled platforms start
building a new RELEASE.linux-x86_64.local is created with
"EPICS_BASE = ", i.e.
> empty. I did not experience this with
> v7.0.5.
> Cheers,
> Pierrick
> Pierrick Hanlet
> Fermi National Accelerator
> Accelerator Front End Controls
> +1-630-840-5555 -- lab
> +1-312-687-4980 -- mobile
> "Whether you think you can or think you can't, you're
right" -- Henry Ford
Pierrick Hanlet
