1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Issue installing StreamDevice on CentOS 7
From: Brandon Gunn via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk at aps.anl.gov
Date: Thu, 15 Jun 2023 11:59:11 -0700
Hello,
I am encountering an issue when attempting to install StreamDevice on our CentOS 7.9.2009 machine using this tutorial (step 7): https://epics-controls.org/resources-and-support/documents/getting-started/
When I run make from ~/EPICS/support/stream/StreamDevice, I get these errors:
$ make
configure/CONFIG:18: /usr/local/epics/base-7.0.3/configure/CONFIG: No such file or directory
Makefile:33: /usr/local/epics/base-7.0.3/configure/RULES_TOP: No such file or directory
make: *** No rule to make target `/usr/local/epics/base-7.0.3/configure/RULES_TOP'.  Stop.
Am I supposed to have an epics directory in /usr/local? I am unsure if this is an issue with setting paths correctly or an issue with my epics base install as I do not seem to see anything with the directory structure .../epics/base-7.0.3/...
Thank you,
Brandon
Re: Issue installing StreamDevice on CentOS 7 Mark Rivers via Tech-talk
Re: Issue installing StreamDevice on CentOS 7 Lang, Keenan C. via Tech-talk
Prev: Re: cross-compiling v7.0.7 Pierrick M Hanlet via Tech-talk
Next: Re: cross-compiling v7.0.7 Andrew Johnson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Prev: Re: cross-compiling v7.0.7 Johnson, Andrew N. via Tech-talk
Next: Re: Issue installing StreamDevice on CentOS 7 Mark Rivers via Tech-talk
ANJ, 15 Jun 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
