1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: add fields to an existing record
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>, "Wolfman, Mark" <wolfman at anl.gov>
Cc: "Delgado, Uriel" <udelgado at anl.gov>
Date: Sun, 18 Jun 2023 15:07:27 +0000
Hi Mark,
Since this new field is intended for use by a single CA client (Ophyd for Bluesky) I think it is a better idea to use additional records and modify Ophyd to handle them.  Then all changes can be external to the MCA module, and Bluesky does not need to depend on a new release of the MCA module.
Note that your gitlab link is not accessible to those of us who are not APS employees.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Wolfman, Mark via Tech-talk <tech-talk at aps.anl.gov>
Sent: Monday, June 12, 2023 11:25 AM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Cc: Delgado, Uriel <udelgado at anl.gov>
Subject: add fields to an existing record
Hi, tech-talkers.
Apologies in advance if parts of this don't make sense, I'm not that familiar with EPICS yet.
I'm hoping to add a new region-of-interest field [1] to the MCA records used in an existing IOC for our DXP fluorescence detector.
Similar to the other ROI fields, I'd like to have ``20bmxmap4b:mca1.R0BH``.
This will be a 'bi' field that doesn't do anything in the IOC, but is used by bluesky/ophyd during staging to determine whether the specific ROI is hinted in bluesky (hence BH for "bluesky hint") [2] and is included in the calculations for summing ROI's across elements. I've added extra records to an IOC before, and so I tried adding this as a record but EPICS complained because my record name included a '.' character.
One solution is to add a record like "20bmxmap4b:mca1_R0BH", but this makes the Ophyd part more complicated since the Ophyd MCA support expects the ROI to have a ``.Rn`` prefix and then tries to append the ``BH`` on the end[3]. Adding a record like ``mca1_R0BH`` means I have to re-write the MCA support in ophyd so I'd prefer to use the ``mca1.RnBH`` PVs if I can.
The full IOC is available on gitlab, though it's presently a work in progress.
Looking forward to hearing any ideas on how to make this work.
[1] https://epics-modules.github.io/mca/mcaRecord.html#Region-Of-Interest_Fields
[2] https://blueskyproject.io/ophyd/user_v1/reference/signals.html#kind
[3] https://github.com/bluesky/ophyd/blob/0802c77ec973b0ba9f8554d3bcf3a3001def7f66/ophyd/mca.py#L14
[4] https://git.aps.anl.gov/20BM/20bmdxp/-/tree/main/
Re: add fields to an existing record Mark Wolfman via Tech-talk
add fields to an existing record Wolfman, Mark via Tech-talk
Prev: Cross-haired xy coordiate from XYGraph Zhang, Tong via Tech-talk
Next: VME configuration : mrfioc2-master version in the new vme-evg-300, vme-evr-300 environment 이민균 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Prev: add fields to an existing record Wolfman, Mark via Tech-talk
Next: Re: add fields to an existing record Mark Wolfman via Tech-talk
ANJ, 20 Jun 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
