On 6/21/23 06:57, Joel Sherrill via Tech-talk wrote:
> For NFSv4, you need libbsd which forces making sure there is
> a driver and configuration for the board you care about.
Does the need to use libbsd effect the availability/function of
the existing PCI drivers for the VME bridge chips?
Some conversations I've listened in on leave me with the impression
that libbsd also includes the BSD PCI driver framework. It is not
clear to me how this would interact with the RTEMS PCI driver
APIs which I am familiar with.
Chris can answer definitively but I think they should except maybe for interrupts. Most of the APIs are access and device id lookup.
- Re: Which VMEbus CPU for EPICS7 and RTEMS? Chris Johns via Tech-talk
- Which VMEbus CPU for EPICS7 and RTEMS? Heinz Junkes via Tech-talk
- Re: Which VMEbus CPU for EPICS7 and RTEMS? Zimoch Dirk via Tech-talk
- Re: Which VMEbus CPU for EPICS7 and RTEMS? Heinz Junkes via Tech-talk
- Re: Which VMEbus CPU for EPICS7 and RTEMS? Joel Sherrill via Tech-talk
- Re: Which VMEbus CPU for EPICS7 and RTEMS? Michael Davidsaver via Tech-talk
Help creating IOC for Lakeshore 336 Brandon Gunn via Tech-talk
<2023>
<2023>
ANJ, 21 Jun 2023 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
