I suspect what you are seeing results from the asyn port not being
connected at the time of the IOC's initial scan.
Firstly, the name "StatusRegister" suggests to me that this value
should be read more than once on IOC startup.
imo. for robust operation some care should be taken anytime when
IOC and device don't share a power switch.
I try to avoid PINI with such devices, and instead use SCAN="10 second"
as a starting point for values which change slowly or only on device
power cycle.
Cheers, ~Ralph
- Strangeness in ai/mbbiDirect with StreamDevice on PINI Leblanc, Gregory via Tech-talk
- Re: Strangeness in ai/mbbiDirect with StreamDevice on PINI Michael Davidsaver via Tech-talk
Display custom TCP data in CS-Studio Vishnu Patel via Tech-talk
Re: Display custom TCP data in CS-Studio Ralph Lange via Tech-talk
<2023>
Re: Strangeness in ai/mbbiDirect with StreamDevice on PINI Zimoch Dirk via Tech-talk
<2023>
ANJ, 27 Jun 2023 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
