1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: Question about fetching history data from MySQL by using phoebus
From: neu lzf via Tech-talk <tech-talk at aps.anl.gov>
To: "Kasemir, Kay" <kasemirk at ornl.gov>, CAOUEN Loic <loic.caouen at cea.fr>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 30 Jun 2023 05:19:23 +0000
Hi Kay and Loic,
Thank you all for the reply and sorry to interrupt again. The problem still exists. I think maybe the problem is MySQL library version.
I use MySQL 5.7.12 on server side (192.168.1.230) and CSS OPI on client side (192.168.1.231). I have done all the MySQL configurations before and CSS are successful to connect to MySQL, while for Phoebus I am still struggling to find the reason.
The configurations for Phoebus are:
org.csstudio.trends.databrowser3/urls=jdbc:mysql://192.168.1.230/archive
org.csstudio.trends.databrowser3/archives=jdbc:mysql://192.168.1.230/archive
Maybe the problem is MySQL library in Phoebus are not suitable to MySQL 5.7.12, I download the mysql-connector-java-5.1.49 from website https://downloads.mysql.com/archives/c-j/, and try to directly replace mysql-connector-java-8.0.30.jar with mysql-connector-java-5.1.49 in Phoebus folder, the path is product-sns-4.7.3-SNAPSHOT/lib/, however the problem still exists. I wonder if the simply replacement is right or maybe java version is the issue.
CSS 4.5.10-SNAPSHOT community edition could connect to MySQL 5.7.12 successfully to read the historic data on the following java environment:
openjdk version "1.8.0_102"
OpenJDK Runtime Environment (build 1.8.0_102-b14)
OpenJDK 64-Bit Server VM (build 25.102-b14, mixed mode)
while, If running Phoebus, I have to change to the java environment below (update-alternatives --config java) and thus failed to connect to MySQL 5.7.12 even if the configuration are the same as CSS for the address of archive Data Server URLs and Archive Data sources, user name and passwords:
java version "16.0.1" 2021-04-20
Java(TM) SE Runtime Environment (build 16.0.1+9-24)
Java HotSpot(TM) 64-Bit Server VM (build 16.0.1+9-24, mixed mode, sharing)
I wonder if java version is the issue and if simply replace mysql-connector-java-8.0.30.jar with mysql-connector-java-5.1.49 is right.  Thanks again !
The error messages are as follows:
URL: jdbc:mysql://192.168.1.230/archive
Error:
java.lang.Exception: Cannot connect to jdbc:mysql://192.168.1.230/archive as root
      at org.phoebus.framework.rdb.RDBInfo.connect(RDBInfo.java:134)
      at org.phoebus.framework.rdb.RDBConnectionPool.getConnection(RDBConnectionPool.java:137)
      at org.phoebus.archive.reader.rdb.RDBArchiveReader.getStatusValues(RDBArchiveReader.java:116)
      at org.phoebus.archive.reader.rdb.RDBArchiveReader.<init>(RDBArchiveReader.java:70)
      at org.phoebus.archive.reader.rdb.RDBArchiveReaderFactory.createReader(RDBArchiveReaderFactory.java:28)
      at org.phoebus.archive.reader.ArchiveReaders.createReader(ArchiveReaders.java:50)
      at org.csstudio.trends.databrowser3.ui.search.ArchiveListPane.lambda$showArchiveInfo$3(ArchiveListPane.java:76)
      at org.phoebus.framework.jobs.Job.execute(Job.java:50)
      at org.phoebus.framework.jobs.JobManager.execute(JobManager.java:54)
      at org.phoebus.framework.jobs.JobManager.lambda$schedule$0(JobManager.java:45)
      at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
      at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1130)
      at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:630)
      at java.base/java.lang.Thread.run(Thread.java:831)
Caused by: java.sql.SQLException: No suitable driver found for jdbc:mysql://192.168.1.230/archive
      at java.sql/java.sql.DriverManager.getConnection(DriverManager.java:702)
      at java.sql/java.sql.DriverManager.getConnection(DriverManager.java:189)
      at org.phoebus.framework.rdb.RDBInfo.connect(RDBInfo.java:130)
      ... 13 more
Sent: 29 June 2023 17:40
To: neu lzf <lzfneu at live.com>
Cc: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
> I try to use binary SNS version of Phoebus and I checked the product/lib folder and found that the file mysql-connector-java-8.0.30.jar is present.
Right, should look something like this :
/jdk/…
/lib/…
/lib/product-sns-4.7.3-SNAPSHOT/lib/mysql-connector-java-8.0.30.jar
When you start it, it’s using the jdk/… that’s included in the download, so the menu Help, About shows java version 17, which should work with that mysql jar file.
When I then try to read data from say jdbc:mysql://localhost/archive, that either works, or it fails with a meaningful error message because there is a connection issue (network, no MySQL running, …) like this :
WARNING [org.csstudio.trends.databrowser3] No archived data for xxx
java.lang.Exception: Cannot connect to jdbc:mysql://localhost/archive as archive
Caused by: com.mysql.cj.jdbc.exceptions.CommunicationsException: Communications link failure
What you see is this :
  1. the connection issue: Cannot connect to jdbc://mysql://192.168.1.230/archive as root
  2. Caused by: java.sql.SQLException: No suitable driver found for jdbc:mysql://192.168.1.230/archive
Check the exact connection string. You mention both
and
The correct syntax is something like jdbc:mysql://localhost/archive
If I try jdbc://mysql://localhost/archive then the extra // indeed turns it into something that’s not recognized as a MySQL connection string, and then “no suitable driver” makes sense for an error.
Re: Re: Question about fetching history data from MySQL by using phoebus lzfneu--- via Tech-talk
Question about fetching history data from MySQL by using phoebus neu lzf via Tech-talk
Re: Question about fetching history data from MySQL by using phoebus Kasemir, Kay via Tech-talk
Re: Question about fetching history data from MySQL by using phoebus neu lzf via Tech-talk
RE: Question about fetching history data from MySQL by using phoebus CAOUEN Loic via Tech-talk
Prev: Re: Phoebus Increased Slider Sensitivity? Tynan Ford via Tech-talk
Next: Help using newest OPC UA Modules/IOCs Marco A. Barra Montevechi Filho via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Prev: Re: Question about fetching history data from MySQL by using phoebus Kasemir, Kay via Tech-talk
Next: Re: Re: Question about fetching history data from MySQL by using phoebus lzfneu--- via Tech-talk
ANJ, 30 Jun 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
