Check the EPICS Record Reference documentation for details on the binary output record. It has a field “HIGH” which specifies the time in seconds for the BO record to remain asserted before resetting itself to zero automatically.
Steven Hartman
hartmansm @ornl.gov
Sent: Friday, January 5, 2024 7:11 PM
To: Hartman, Steven <hartmansm at ornl.gov>
Cc: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: RE: [EXTERNAL] Representing stateless device commands?
Thanks Steven and Mark, for your welcoming and helpful responses.
I have the streamDevice proto files written, and am at the point where I’m wondering if there’s an easy way to capture what Steven is suggesting – forcing the PV back to zero immediately after the RS232 command “IncreaseBrightness” has been sent, such that
the state of the binary PV “MYLED:IncreaseBrightness” represents whether we are “in process” of “Increasing Brightness”?
Here’s what I have in mind as far as sequence:
“MYLED:IncreaseBrightness” is 0, its regular state.
I invoke “caput MYLED:IncreaseBrightness 1”, changing the PV from 0 to 1.
StreamDevice follows its protocol for processing a change in the PV, and sends an RS232 message of “IncreaseBrightness” to the device. StreamDevice awaits no reply, as the device gives none.
[Somehow?] “MYLED:IncreaseBrightness” is now automatically forced back to 0.
I have steps 1-3 under control with StreamDevice, so I’m wondering about best practices to implement Step 4.
Thanks!
Scott
Sent: Friday, January 5, 2024 1:22 PM
To: Feister, Scott <scott.feister at csuci.edu>
Subject: Re: [EXTERNAL] Representing stateless device commands?
CAUTION: This email originated from outside of CSUCI. Do not click links or open attachments unless you validate the sender and know the content
is safe. Contact ITS if you have any concerns
My approach right now is to call them binary outputs (bo) records
Yes, that sounds about right.
You can use the ONAM and ZNAM fields of the BO record to name the two states which may convey that it is indeed a process variable that is either doing something (i.e., increase the brightness) or not. In EPICS, pretty much everything is a process variable.
- RE: [EXTERNAL] Representing stateless device commands? Feister, Scott via Tech-talk
- Representing stateless device commands? Feister, Scott via Tech-talk
- Re: [EXTERNAL] Representing stateless device commands? Hartman, Steven via Tech-talk
<2024>
<2024>
ANJ, 11 Sep 2024 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
