My 2cts...
What you describe seems to be pretty much the container equivalent of system packages that install IOC binaries. (In addition to the IOC binary, the image will need to provide DBD information for the compiled-in modules.) I would expect issues and maybe limitations roughly in the same areas, then, especially regarding usability for other facilities. A lot depends on how exactly you define "class of device". Some roughly sorted thoughts:
I generally like the idea, for sure. But with the amount of code that can be generated, added and needs to be linked in... "viable for use in any facility" might be challenging. This is comparable to the binary distribution for the OPC UA Device support: that started with distributing IOC binaries, but it didn't work. ( "I need iocStats." "I need the <whatever> record." "I need QSRV/pvAccess." "How do I add a state machine?"...) The current way of distributing shared-library plus DBD leaves compiling the final IOC binary to the users, allowing them to add their specific code. Cheers, ~Ralph
ANJ, 16 Jan 2024 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
