1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024
Subject: RE: How to achive a huge number of PVs in Archive Appliance
From: Sky Brewer via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Mon, 22 Jan 2024 16:13:53 +0000
Hi Loïc,
You can use the rest api to submit PVs to be archived. We maintain a python library that can read files listing PVs and submit them to be archived at https://gitlab.esss.lu.se/ics-software/py-epicsarchiver
Excitingly, you can also use ChannelFinder (from v4.7.2) to submit PVs to be archived. Setting a configuration of:
################ Archiver Appliance Configuration Processor #################
aa.urls={'default': 'http://localhost:17665'}
aa.default_alias=default
aa.enabled=true
aa.pva=false
aa.archive_property_name=archive
aa.archiver_property_name=archiver
Any PV with an info tag of “archive” to “default”, or even [email protected] will be sent to the default archiver with the default policy or using Monitor at 10Hz.
Hope that helps.
Sky
RE: How to achive a huge number of PVs in Archive Appliance CAOUEN Loïc via Tech-talk
Re: How to achive a huge number of PVs in Archive Appliance William Kirstaedter via Tech-talk
Prev: Re: How to achive a huge number of PVs in Archive Appliance Ralph Lange via Tech-talk
Next: RE: A question on asyn application Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024
Next: RE: How to achive a huge number of PVs in Archive Appliance CAOUEN Loïc via Tech-talk
ANJ, 06 May 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
