1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024
Subject: Re: known problem with the reccaster on Windows?
From: Heinz Junkes via Tech-talk <tech-talk at aps.anl.gov>
To: Mark Rivers <rivers at cars.uchicago.edu>
Cc: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Wed, 31 Jan 2024 10:19:19 +0100
After I removed recaster. the autosave works.
elsave_restore: Can't open save file.iocRun: All initialization complete #makeAutosaveFileFromDbInfo("/srv/ioc/log/as/req/${IOC}_0.req", "autosaveFields_pass®")
#makeAutosaveFileFromDbInfo("/srv/ioc/10g/as/req/${IOC}_1.req", "autosaveFields_pass1")
#create
_monitor_set("${IOC}_0.req"
' , 5, "Р=${IOC}:")
#create_monitor_set("${IOC}_1.req", 30, "P=${IOC}:")
# save things every
thirty seconds
nicreate_monitor_set("auto
_settings.req", 30, "PLF1:")
-save_restore:readReqFile: unable to open file commonPlugin_ settings.req. Exiting.
epics> auto_settings.sav: 96 of 96 PV's connected
epics ›
epics > epics>
240131-101515]
reepics› save_restore:write_save_file: Backup file (•/autosave/auto_settings.savB)
I'll have a look for the version later.
Danke Heinz
Fritz-Haber-Institut    | Phone:         (+49 30) 8413-4270
Heinz Junkes             | Fax (G3+G4):   (+49 30) 8413-5900
Faradayweg 4-6        | VC: https://zoom.fhi.berlin/junkes
D - 14195 Berlin        | E-Mail:        junkes at fhi-berlin.mpg.de
> On 30. Jan 2024, at 15:42, Mark Rivers <rivers at cars.uchicago.edu> wrote:
> P {margin-top:0;margin-bottom:0;} Hi Heinz,
> What happens if you build ADLightField without reccaster?
> Have you tried running the ADSimDetector, also built with reccaster?
> If you build with the windows-x64-debug architecture then you can debug with Visual Studio and perhaps get more information on what it happening in doCasterTCPPhase.
> Mark
> From: Tech-talk on behalf of Heinz Junkes via Tech-talk
> Sent: Tuesday, January 30, 2024 5:11 AM
> To: EPICS Tech Talk
> Subject: known problem with the reccaster on Windows?
> Hi,
> I'm trying to get the autosave working on an IOC running on Windows.
> Unfortunately the IOC hangs at iocInit(?) and I can't debug any further.
> Unfortunately, I can't figure it out on Windows (I simply have zero experience with it) and maybe I'm just being stupid.
> There is an IOC in the areadetector for the Lightfield application. When starting the IOC we get the following error message:
> restore: Can t open save file. locRun: All initialization complete
> epicsSocketDestroy: failed to close a socket because "An operation was attempted on someth ing that is not a socket. "
> casterInit failed to create shutdown socketThread win994 (00000112429708B0) can't proceed, suspending.
> Dumping a stack trace of thread 'win994':
> [ 00007FFF05B709CF](epicsStackTrace+0x7f)
> [ 00007FFF05B5E934] (cantProceed+0x94)
> [ 00007FFF128044DB] (doCasterTCPPhase+0x7fb)
> [ 00007FFF05B58B85] (initHookAnnounce+0xc5)
> [ 00007FFF0539EF71] (iocRun+0x151)
> [ 00007FFF0539F152](miscIocRegister+0x162)
> [ 00007FFF05B56E57](iocsh+0x1127)
> [ 00007FF6A2D63B43]
> [ 00007FF6A2D62B90]
> [ 00007FFF2DCF7344] (BaseThreadInitThunk+0x14)
> [ 00007FFF2F6C26B1]RtlUserThreadStart+0x21)
> We are running reccaster …
> Is this a known problem with the reccaster on Windows?
> Danke Heinz
Attachment: smime.p7s
Description: S/MIME cryptographic signature
known problem with the reccaster on Windows? Heinz Junkes via Tech-talk
Re: known problem with the reccaster on Windows? Mark Rivers via Tech-talk
Prev: Mobile web client for Clog 2.0 Wang, Lin via Tech-talk
Next: motor model 3 with binary commands PiCo 33 piezo CN30 controller Sintschuk, Michael via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024
Prev: Re: known problem with the reccaster on Windows? Mark Rivers via Tech-talk
Next: Re: known problem with the reccaster on Windows? Michael Davidsaver via Tech-talk
ANJ, 31 Jan 2024 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
