We don't use reccaster in in the upgraded APS, but we have adopted the naming convention (from Python?) that record names which end in an underscore '_' are intended for internal use within the control system
only, and shouldn't be used on any published display screens or by other clients. We haven't gone so far as to remove them from the lists of PV names that our name-servers recognize (which would limit access to other IOCs or clients running in the same subnet),
but that would be our equivalent to what Daniel is asking for.
I would think it should be relatively easy to filter out matching names like that inside the reccaster code, whereas searching for an info tag in each record would probably slow up the reccaster somewhat at
start-up. The use of a naming convention also makes it easier to see when someone is using a PV name that they aren't supposed to be connecting to.
- Andrew
Complexity comes for free, Simplicity you have to work for.
On 5/9/24, 5:25 PM, "Tech-talk" <tech-talk-bounces at aps.anl.gov> wrote:
Hi Daniel,
I am not aware of any field like that but it does sound like an interesting idea. Another place you could filter PVs before they reach channel finder is on the recceiver side, in the cfstore plugin.
Hello all,
I have been working with LLNL on an EPICs application. The Channelfinder has critical functionality we would like to take advantage of, but one of the hurdles is limiting what records are allowed to be published through the reccaster module. I don’t want the
end user to have visibility into every single record an IOC has, but I am unclear if the support module offers this functionality. Is there some field I can add to relevant records so that reccaster only publishes those PV’s?
Thank you for your time,
Daniel Kenner
Computer Engineer
Lawrence Livermore National Laboratory
Phone: (925) 758-2607
Email:
kenner2 at llnl.gov
- Channelfinder Recsync Client: Limit records client side Kenner, Daniel Craig via Tech-talk
- Re: Channelfinder Recsync Client: Limit records client side Tynan Ford via Tech-talk
RE: Channelfinder Recsync Client: Limit records client side Kenner, Daniel Craig via Tech-talk
RE: About the timestamp in py-epicsarchiver lib? Zhang, Tong via Tech-talk
<2024>
Limitations of some EPICS base's records Abdalla Ahmad via Tech-talk
<2024>
ANJ, 10 May 2024 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
