Hi Joao,
From my personal view, I don't recommend running two IOCs on one RT system, since the RT system must be dedicated to their own specific tasks even if we can do.
Best, Han
Hello all,
This is a very interesting topic. I have an example and would be nice to get some guidance on how to proceed.
Let’s say there are two IOCs running in the same host (which has Linux PREEMPT_RT, btw). The IOC A has a record that gets updated at 10 Hz (via hardware interrupts). The IOC B has a
record that gets updated and fetches its timestamp using the TSEL link (with CPP) mechanism from that 10Hz PV of the IOC A.
Which are the threads (in both IOCs) that I should elevate priority or run in dedicated cores that will improve the determinism of this operation? (not interested in reducing the latency,
but to know that this latency won’t be more than N micro/milliseconds).
Thanks in advance (and sorry for deviate from your original question, Dave!)
João Paulo Martins
That is more or less the basic setup.
Note that there are already network specific threads in this list, which are generated per network interface configured.
When EPICS network connections are active, the server(s) on the IOC will usually start one pair of threads per client.
If your IOC uses the parallel callback threads functionality (to utilize parallel processing on multiple CPUs), there will be (highly configurable) more instances of the cbLow/cbMedium/cbHigh threads.
Many drivers and device support modules start their own threads. ASYN ports often have a thread associated with each port, AreaDetector plugins (as they are implemented as ASYN ports) most often start a thread per plugin.
MCoreUtils is a module that you can use to have more control over priorities, scheduling mechanisms and CPU allocation of IOC threads. This is convenient when you're running real-time applications on the same host and want to keep the IOC
from running on your dedicated real-time core(s). (Except maybe for that one device support thread that does the communication between the IOC and the real-time parts...)
Jeong Han Lee, Dr.rer.nat. Lawrence Berkeley National Laboratory
- EPICS and EPICS+PVXS internal threading of IOCs Dave Bracey via Tech-talk
- Re: EPICS and EPICS+PVXS internal threading of IOCs Mark Rivers via Tech-talk
- Re: EPICS and EPICS+PVXS internal threading of IOCs Ralph Lange via Tech-talk
- Re: EPICS and EPICS+PVXS internal threading of IOCs Joao Paulo Martins via Tech-talk
Re: ADUrl and digest authentication Heesterman, Peter via Tech-talk
<2024>
ADUrl and digest authentication Tomasz Brys via Tech-talk
<2024>
ANJ, 17 May 2024 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
